Austin 1800 engine
7 replies to this topic
#1 mini_kev
mini_kev
  • 716 posts
Posted 20 June 2007 - 03:19 PM
does anyone have any information on the austin 1800 engines? Mainly just the cylinder head. Tried doing a search but nothing relevant came up.
Dont worry im not thinking about dopping one into my mini that would be foolish, just want to have a look at something to do with the cylinder head.
thanks
#2 mini13
mini13
  • 3,811 posts
Posted 20 June 2007 - 05:05 PM
what do you need to know?
the 1800's B series head is pretty similar to a small bore A series head but bigger.
#3 mini_kev
mini_kev
  • 716 posts
Posted 20 June 2007 - 11:01 PM
basically will the head off an 1800 fit the block of a 1275?
Obviously im not expecting it to bolt straight on but does it line up with the a-series block or is this not possible at all? Im doubting wether it will as one is a and the other b series plus with the difference in engine volume i doubt the cylinders will line up with the combustion chambers on the head?
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 21 June 2007 - 02:41 AM
For information on the 1800, don't look for it by Googling for Austin. Google MGB. The block is wider and longer than the A-series so the head is correspondingly bigger.
#5 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 21 June 2007 - 08:17 AM
"They" say that BMC put an 1800 B series in one of the Italian Job Mini's......
#6 mini_kev
mini_kev
  • 716 posts
Posted 21 June 2007 - 09:53 AM
so its a no no then
#7 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 21 June 2007 - 10:07 AM
may dad had a mini with a Maxi 1750 engine in it.
#8 Ethel
  • 26,074 posts
Posted 21 June 2007 - 10:19 AM
Most unlikely head swap for lots of reasons and there'd be better and easier options.
B Series went into the MGB so I bet there's enough info on the web if you look.
