Rial Challenge Rims
11 replies to this topic
#1 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 22 June 2007 - 10:21 AM
I spotted these on the Fluke website and thouught they looksed quite nice. They come in 13x7, 13x7.5, 13x8, 13x8.5, 13x9, 13x9.5 and 13x10.
I thought a set in 13x7.5 would go nice on my Vaux project, as iv never seen any before. Her is the spec
Rial Challenge 13"x7" wheels £179.00
INFORMATION
RIAL's newly developed a three-piece 13" modular wheels showcases the established company's talents. The wheel has many advantages over similar wheels currently offered on the market.
The main objective of the new design was to optimise weight - weighing in at 4.9kg a wheel (13"x7") but with strength of a wheel twice the weight.
The wheel-center is available in a range of colours, finished in three-layer powder/wet-coating.
The outer rim is clearcoat sealed and a high gloss surface polish can be applied on request.
The three piece design ensures ease of repair and/or change of offset with a standard off-the-shelf tool used on the bolts.
Guaranteed to be perfectly balanced (cyclic tested)
These rims are extremly strong, subjected to over 800,000 load change tests without any cracks whatsoever - far exceeding TÜV-regulations by more than three times!
The wheels have been impact-tested by the German TÜV.
Load approved and certified by German TÜV.
High-grade steel bolts are used throughout giving strength and corrosion resistance.
The three pieces are sealed with o-rings for absolute airtightness - no liquid silicon is used like the lesser wheels on the market.
PCD for Caterhams/Westfields/etc.
Supplied with strong, light alloy wheel nuts (60° eloxy Aluminium M 12 x 1.5, open-ended).
Manufactured under DIN ISO 9001:2000
In summary, perfect quality rims, as you would expect when made in Germany!
Seem to be really light, strong and perfect for track use.
Has any once ever seen or come across them before?
#2 mike.
mike.
  • 6,176 posts
Posted 22 June 2007 - 10:25 AM
Man they look sweet. But is the £179 price without tyres?! Bit steep
#3 PhoenixSimon
PhoenixSimon
  • 1,050 posts
  • Local Club: BOGMOC
Posted 22 June 2007 - 10:29 AM
mmmmmm shiney split rims!!!!!! :P
#4 mike.
mike.
  • 6,176 posts
Posted 22 June 2007 - 10:46 AM
How do they compare in weight to a set of superlight 13x7s?
#5 Dom
Dom
    Moved Into The Mazda
  • 10,685 posts
Posted 22 June 2007 - 10:56 AM
Very Nice :P
#6 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 22 June 2007 - 10:58 AM
Nothing compared to some wheels really.
#7 Dev
Dev
    Fiat 500 'Ringer
  • 1,549 posts
  • Local Club: NF500
Posted 22 June 2007 - 11:26 AM
what tyres you planning to use?
as the 048r's would need stretching a tad
#8 mike.
mike.
  • 6,176 posts
Posted 22 June 2007 - 11:48 AM
Yer i suppose if they're light they're well worth it performance wise
#9 Mephiston
Mephiston
  • 386 posts
  • Local Club: London and Surrey
Posted 22 June 2007 - 11:57 AM
they look really good, some split rims look a bit too busy if you know what i mean - where as those are just nice, specially with the black and some nice 4 pots in red behind, BEAST! :P
#10 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 22 June 2007 - 11:59 AM
Superlights are:
13 X 7"
7N
93 mm
6.00 Kg
#11 Sam Walters
Sam Walters
  • 2,765 posts
Posted 22 June 2007 - 12:11 PM
:P very nice, so expensive tho!
#12 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 22 June 2007 - 01:18 PM
Nice, if only they made 12's :P
