My paint finish on bonnet
3 replies to this topic
#1 james962
james962
  • 2,677 posts
Posted 28 June 2007 - 06:52 PM
Hey, i've recent sprayed a new bonnet and when i applied the laquer, the finish went in an "orange peel" effect. ;D
Before i applied the laquer, and poured some water over the paint, the finish looks perfect, a sharp reflection. When i put on the laquer, the finish has gone all "orange peelly". I guess this may be due to the ration of laquer to thinners, but im not sure. What is the correct ratio, and if this is not the problem, what could be the cause?
Oh yeah, another thing, i am using a compressor (just incase you were wondering)
Cheers James
#2 dave87
dave87
  • 169 posts
Posted 28 June 2007 - 07:07 PM
wet flat the laquer untill its not orange peely anymore and it will go dull then buff it and it should be ok
dave
Edited by dave87, 28 June 2007 - 07:09 PM.
#3 james962
james962
  • 2,677 posts
Posted 28 June 2007 - 07:46 PM
Cheers for the quick reply, i will try it tomorrow when hopefully the weather is a bit better. Cheers again.
#4 adyzr1
adyzr1
  • 257 posts
Posted 28 June 2007 - 08:56 PM
1500 wet and dry with lots of soapy water (wipe dry as you go and check its smooth matt)then same process with 2000 wet and dry , then polish up with farecla 600 compound and machine polisher should be like glass!
Edited by adyzr1, 28 June 2007 - 08:57 PM.
