tachometer problems
Posted 29 June 2007 - 09:01 AM
+v terminal - therefore electrical current must be making its way through the tachometer circuit fine. when testing it i started the car and revved it the voltage fluctuated from just under 12v to just over on my volt meter tester (testing the earth terminal). maybe something is stuck - does anyone know of any typical problems with tachometers in this manner? are there any other ways of testing it such as direct to the battery for ease in testing etc?
cheers
dan
Posted 29 June 2007 - 10:57 AM
Have another look at the loom. Where you have found that white/black there should also be a green with a spade on the end. These should both be taped together and taped back to the outside of the loom by the multi-plug for the clocks. The other end of the white/black should be hanging around near the coil.
You really need the 3 clock PCB if you are just adding a tacho to an existing 2 clock. The PCB carries the tacho lamp connection and the earth for it too. You can fiddle an earth by fitting an eyelet to some cable and trapping it under the earth screw on the tacho, then do the same at the other end to join it to another earth on the clocks. Fitting the lamp is a lot harder without the pcb, you may be able to solder some leads to the bulb holder and fit one to your new earth jumper and the other solder to the clock lighting track. It is fiddly without the PCB.
The only problem I've encountered with the rev counter on my Mini, was when my wiper motor park-switch failed. So if you're wipers don't park themselves, or only work intermittent, replace you're park-switch, because it runs on the same circuit as you're instruments and heater blower motor and it can either cause that particular fuse to keep blowing or for the gauges to misread.
Well I thought it was worth a mention anyway: -
I've also heard that there can be compatibility issues between instruments used for injection and not injection Minis. Plus Smiths and Nippon Seiki Instruments don't always work well together too?
Posted 29 June 2007 - 12:27 PM
cheers
dan
Posted 29 June 2007 - 12:58 PM
Posted 29 June 2007 - 01:39 PM
can i test the tacho with the engine off then or does it need to be revved up?
cheers
dan
Posted 29 June 2007 - 02:30 PM
Edited by Jimmyarm, 29 June 2007 - 02:31 PM.
Posted 29 June 2007 - 03:13 PM
Posted 29 June 2007 - 06:00 PM
The two terminals you have found on your tacho are supply and sensing, neither is earth (which is negative). The tacho is an instrument, not just a dumb cicuit device. It runs off the power supplied through the supply and earth and only displays when it senses an intermittant earth connection at the sensing terminal There is a screw on the back of the casing that needs to be connected to the PCB and this is the earth for the instrument. Your tacho is not powered until it has both supply and earth. All this is detailed in the quote that Taffy kindly provided above. A tacho will not work if it's simply plugged in, it needs an input from the ignition for it to sense or it won't display anything. If it just made up a reading for itself what would be the point of it?
Posted 28 June 2017 - 02:30 PM
Replace Black & White Tachometer Clock wire from the Ignition Coil and re-feed.
Check park switch wiper-motor connections.
Then replace the black and white wire connection to the clock and check earth screws are in place to the circuit board.
Cut off black and white wire end and fit a bullet connection slot terminal to the clock and hit into the gold pin with a rubber mallet, and then connect the black and white wire from the ignition coil to the clock feed, and then you should have a green and orange wire as well to the clock.
This is a video explaining how I fixed my tachometer connection after fitting a new dashboard, this is a common issue... the main issue is the connection when you pull the wire off the clock gold pin, as the wire gets damaged inside the connection as most people pull it off with pliers as the wire is hard to get off.
Hope this helps
Like the video if this helps:
