Stupid brakes...
Posted 29 June 2007 - 04:46 PM
I'm having trouble getting a decent pedal in my Van...
I am running a single line system...
I've replaced the Master Cylinder, all the rear brakes (which I have found hat I now have a leaky cylinder, even though it was new :mad:) I have Cooper S 7.5" Calipers on the front, I've bleed, them and bleed them, and can't get any more air out from pumping the pedal.
When it goes "harder" it still nearly hit the floor, and its now where near as hard as it used to be (even that was poor) but its goes perfect after pumping the pedal about 5-6 times.... Once its hard if you keep the pressure on, the pedal stays hard.
So going to replace my cylinder, what else can it be that can cause such a weak pedal?
Also, I've noticed that with one side built up, its "stiff" to turn, and adjustment is minimal before it stops (perfect adjustment) but the otherside, spins round nicely, but I have no adjustment at all... like I said I've bought brand new built up back plates... I've racked my brains and I really CBA now...
HELP!!
Posted 29 June 2007 - 04:57 PM
We had to replce the master cylinder, and all the seals with it. then power bleed the brakes abuot 4 times then bleed them propperly
Posted 29 June 2007 - 05:00 PM
But now I've got the rear cylinder gone, I can't adjust it up, so will have to wait for a new cylinder...
But something that I've just thought off... before I found all this out, I found I couldn't get the drivers side to adjust tight (in fact it never adjusted full stop.) what could this be?
Posted 29 June 2007 - 05:06 PM
Posted 29 June 2007 - 05:08 PM
Posted 29 June 2007 - 05:18 PM
Posted 29 June 2007 - 05:29 PM
Posted 29 June 2007 - 05:39 PM
once thats sorted i find a long length of fish tank hose from the bleed nipple back to the master cylinder works well, you can then pump it nice and quick to force all the air out of the high spots.
Posted 29 June 2007 - 05:47 PM
Posted 29 June 2007 - 08:39 PM
When my system was completely empty i had the car up on stands, filled the master cylinder up full left the cap off then opened all the bleed nipples. A few minutes later it started started to come through the nipples so i then closed them off and bled the brakes the normal way
Perfect pedal.
Hmmm wouldn't that put air-infused fluid into the master cylinder though????
Posted 29 June 2007 - 09:00 PM
As for changing the master to a Cooper S one, no idea,I got a plastic bowl type - non-orginal - off Minispares...
Posted 30 June 2007 - 10:07 AM
Posted 30 June 2007 - 10:34 AM
A phone call will be made on Monday, see if I can get a replacement (and darn Simon's on holis
Posted 30 June 2007 - 06:10 PM
If you want to check whether you have a brake or clutch M/C, the only external difference between the two is the shape of the baseplate.
Posted 01 July 2007 - 10:43 AM
