I have a Mini Mayfair 1996, 1275 injection, and the engine isn't running correctly.
This all started happening at the same time:
Basically it struggles to start (most of the time, but not always) when it's cold, but is pretty much fine if the engine is already at normal temperature.
Once it is running, the idle speed varies wildly, changing between around 800 and 1200 rpm, but sticking towards 1200. (Before all this it idled at around 800 rpm without any problem). It also spikes to around 2000-2200 rpm randomly, and drops to almost stalling point randomly too.
When it is still cold, it drops more frequently, often to the point of stalling.
If you rev the engine, whereas it would usually drop back down to 800 rpm smoothly, it currently drops to around 2000-2000 rpm and hangs around there for maybe 5-30 seconds, before dropping down to the 800-1200 rpm range.
So - any ideas guys?
Thanks a lot in advance for any suggestions.
Edit:
Also just remembered, the varying revs are to thet point where even if you are driving along at a steady speed say 40 mph, you can feel it pulling forward and dropping back as it varies. Also, the unnaturally high revs sometimes mean that if you accelerate towards say 25 mph in 3rd gear, then shift to 4th gear, the car will keep accelerating itself for a bit without even pressing the accelerator.
Edited by l_bratch, 03 July 2007 - 02:11 PM.
