Wiring to starter motor
10 replies to this topic
#1 AlexM
AlexM
  • 1,302 posts
  • Local Club: NMOC, ECMC
Posted 08 July 2007 - 09:37 AM
Could someone please tell me how the wires are arranged on the starter motor. I thought i took a photo before i took them off but ive forgotten. I know that one goes to the top bolt and that three more go onto the solenoid....i think....but which way round?
thanx
#2 Ethel
  • 25,967 posts
Posted 08 July 2007 - 10:39 AM
thanx
There should be a thick brown wire that goes on the same connection as the battery cable - on the solenoid.
Another terminal will make the solenoid go click that wants to go to the starter post on your ignition switch, think it's a red 'n white wire that should also supply a wire to your ignition coil, bypassing the ballast resistor, think that one's white 'n yellow.
There's also a short bridging cable from solenoid to the motor.
#3 Dev
Dev
    Fiat 500 'Ringer
  • 1,549 posts
  • Local Club: NF500
Posted 09 July 2007 - 01:03 PM
I'll have look for you tonight if its not raining.
Dont reconnect the battery untill you know as you will possibly fry the ECU
#4 AlexM
AlexM
  • 1,302 posts
Posted 10 July 2007 - 02:23 PM
yeh, the concequences of getting it wrong could be very bad :P
Isn't it just the earth wire that connects to the top mounting bolt....with the others going to the solenoid....could someone confirm this for me as i don't want to get it wrong....thanks :thumbsup:
#5 mini_dave
mini_dave
  • 505 posts
Posted 10 July 2007 - 10:29 PM
theres a pic i took not long ago, hope that helps a little (just ignore the pink arrow lol)
Edited by mini_dave, 10 July 2007 - 10:30 PM.
#6 GraemeC
GraemeC
  • 7,438 posts
Posted 11 July 2007 - 08:59 AM
My thoughts would be:
The two on the left to the copper coloured stud - one will be the main power feed, the other will be the feed to the alternator etc.
The earth strap, which looks like it needs a new ring terminal crimping on, can go to the main starter securing bolt - not to any connetion on the back of the starter or solenoid.
I presume the wire from the ignition barrel, with a large spade connector on the end, is already in place?
#7 AlexM
AlexM
  • 1,302 posts
Posted 11 July 2007 - 10:41 AM
Anyone got a photo of the wiring for an spi...I don't want to get this wrong.
#8 AlexM
AlexM
  • 1,302 posts
Posted 13 July 2007 - 09:50 AM
help. :s
Edited by AlexM, 13 July 2007 - 09:50 AM.
#9 trickyd
trickyd
    Starting My Mini Up
  • 2 posts
Posted 26 May 2008 - 11:50 AM
help. :s
Alex - did you get an answer as I have the same problem....
#10 marco.h
marco.h
  • 116 posts
  • Local Club: Not got joined yet....
Posted 26 May 2008 - 12:56 PM
ditto, i need to reconnect mine later on, i will refer to trusty haynes see if he has the answer...
#11 chapaz18
chapaz18
  • 11 posts
  • Local Club: Southern Mini Owners Club
Posted 30 August 2009 - 03:58 PM
hey, ive recently bought a high torque starter motor an just wondering if anyone knows how to wire the thing! my stepdad said there are four wires and only two connection points on the starter motor, we know where three of the connections go, but the other is a tricky one! does anyone know about this spare wire?
let me know thanks
tom chapman
