People call the cold manifold effect carb icing, but Ethel is right in that it isn't quite the same thing. An alloy manifold will run very cold if unheated, the original cast iron one is heated by the exhaust manifold as they are the same lump of iron. The problem with a very cold manifold surface is that it causes the fuel to condese out of the charge and form droplets on the surface which will then run into the cylinders as a liquid. Liquid fuel doesn't burn too well, petrol only burns as a vapour. This is why the carb is there, to atomise the fuel and the liquid petrol dripping into the cylinders does odd things. It makes the engine run poorly since it can't burn until it's evaporated meaning it burns later than the atomised fuel in the charge and you get a very unreliable burn as a result. Having warm manifold walls prevents this and doesn't really heat the charge very much. It does mean that the charge is almost always at the same temperature when it enters the engine and so the engine will stay in tune better nomatter what the whether was like when it was setup. This is what manifold heating is for and is why almost all road cars have heated manifolds. To keep it evenly heated all the time it is best to put it in parallel with the heater circuit so the valve won't turn it on or off. You need some heater hose and some coolant line tee pieces, it's easy enough. If you have the valve on the head you would need to convert to an inline valve to be able to run it like this but a 1991 car should have the inline valve already. Take coolant from the heater line before the valve, run it through the manifold and return it to the heater hose just before it meets the bottom hose.
Carb icing is different and is actually the formation of water ice crystals inside the carb due to low ambient temperatures coupled with the refridgerating effect of evaporating fuel and high humidity in the incoming air. It freezes the throttle spindle, jet and piston (in an SU) solid and really affects the running of the engine. SU carbs fitted to aero-engines (as used with Merlin and Griffin engines in the Spitfire and other fighters) had oil fed butterflies and throttle spindles and other engine heated parts to get around this. Minis and other BL cars sold to the Scandinavian market in the 70s had electrically heated carb suction chambers and carb bodies along with inlet manifold heating to combat both effects.
Edited by Dan, 11 July 2007 - 11:54 AM.
