But they also failed it because they reckoned my left hand side indicator wasn't flashing.
Well my Mini was laid up for some 3 years, but now it's been used a bit the indicators are both flashing at the normal rate when the engine is running, however the left hand side stops flashing when the brake pedal is pressed and it just stays on.
I've owned my Mini for well over 13 years, so chances are it's the original indicator flasher unit/relay. But I have ordered a replacement just in case.
But since the existing one is working well until the brake pedal is pressed, could there be a short somewhere or a bad earth?
If so where should I start looking, because everything else electrical is working fine. to be honest I think it's been like that for years anyway, but any advice will be greatly appreciated as I only have till next Saturday to get it sorted.
Edited by taffy1967, 14 July 2007 - 12:00 PM.
