Adding a tach - suggested shift point/redline?
11 replies to this topic
#1 ImagoX
ImagoX
  • 259 posts
  • Local Club: MidOhioMotoring.com
Posted 16 July 2007 - 09:26 PM
My '92 does not have a tach (only the standard 2-gauge binnacle). I bought a nice Sunpro rev counter unit that I'll be installing soon, but I wonder what the redline is for a non-modded, 1275 single-carb engine? I was planning on marking the redline, not the recommended shift point, but I can do that as well if someone has the figures.
Thanks in advance!
#2 Se7enS1ns
Se7enS1ns
  • 472 posts
Posted 16 July 2007 - 09:35 PM
Suppose it is completely down to personal preferance at the end of the day. There is a defined "peak" for each engine, where anything over that peak, although isnt going to destroy the engine, wont gain anything further.
I'd hazard a guess around 5500 mark?
#3 ImagoX
ImagoX
  • 259 posts
Posted 16 July 2007 - 09:38 PM
I'm much more concerned with the "destroy the engine" value... My 1275 is certainly fun, but fast, it ain't. :shifty:
#4 Big_Adam
Big_Adam
  • 7,435 posts
Posted 16 July 2007 - 09:44 PM
I shift around 5500 on my 998. If your concerned just shift sooner. Think 5500 is normally the peak of torque or somthing (I may now be talking complete rot). If your concerned just shift sooner.
#5 chairchild
chairchild
  • 606 posts
Posted 16 July 2007 - 10:22 PM
5500, unless balanced, lightened, or a centre strap has been fitted
#6 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 16 July 2007 - 10:31 PM
6000 absolute max and your shift point is going to be around 3200 as max torque is around 2700
center strap not required unless the engine repeated stays above 7000 same can be said for lightening stuff, and the factory balance is good for 6500
Edited by Mini Sprocket, 16 July 2007 - 10:34 PM.
#7 the_bandit
the_bandit
  • 31 posts
Posted 17 July 2007 - 06:38 AM
heres my tach , recently fitted iv got the red line at 5500 but its never round there , {usually past it haha}
Edited by the_bandit, 17 July 2007 - 06:38 AM.
#8 ImagoX
ImagoX
  • 259 posts
Posted 17 July 2007 - 02:19 PM
Thanks very much guys! I'll set my redline at around 5500 and plan to shift at around 3000...
Bandit - I was thinking of mounting the tach down next to the binnacle OR actually on top of the dash rail... How's the visibility of the gauge down low like that? Mounting it on top of the rail is certainly more visible, but it's also less stealthy to people looking into the car.
#9 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 17 July 2007 - 02:44 PM
What a cracking/classic dash, I bet it's great fun watching those dials spin around when you give it some welly. :shifty:
#10 Se7enS1ns
Se7enS1ns
  • 472 posts
Posted 17 July 2007 - 02:46 PM
I personally have mine mounted on top of my Works rally dash, so that its directly in my line of sight. This is mainly 'because i drive by mine, i keep shearing speedo cables so have the speeds worked out as per engine revs / gear.
#11 *DJH*
*DJH*
  • 4,972 posts
Posted 17 July 2007 - 02:51 PM
The best option i would've poted for would be a basic RR session, then that'll definately tell you what the max is.
Daniel
#12 Leonard
Leonard
  • 784 posts
  • Local Club: mini rebels
Posted 17 July 2007 - 04:59 PM
for best acceleration through gears, I found it best to shift at about 5000. the torque drops of quickly after this.
