Subframe mountings
6 replies to this topic
#1 Pavel
Pavel
  • 2,451 posts
Posted 30 December 2004 - 02:21 PM
After a few test drives of my car today I noticed something.
If braking really hard (locking wheels) there is a kind of thump (once) from the front of the car, kind of how an engine knocks about when the steady bushes are gone. But it is a one time knock only when braking suddenly.
Is this indicating worn subframe bushes? If so I guess I'll just order a solid mount kit and replace all the mounts (floor, tower and front panel).
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 30 December 2004 - 02:49 PM
Could be i was getting a knock....then the engine steady snapped.....turned out to be subframe worn mounts.
#3 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 30 December 2004 - 03:31 PM
i got a nock under hard braking or downshifting, its the subframe mounts coming loose as i could see the 2 bolts moving lol
all fixed now though
#4 Spannermonkey6464
Spannermonkey6464
  • 587 posts
Posted 02 April 2007 - 06:39 PM
Hi looking to change the two front subframe mounts but is it possible to change them with the subframe in place?? (by supporting both car and subframe and then removing front two?)
would be greatful for advice on this one, thanks guys
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 02 April 2007 - 07:14 PM
You mean the front teardrop mounts? You can change them without supporting anything really (except the car obviously!). Same for the toe board mounts pretty much. It's only when you remove the two tower bolts that things get tricky. You shouldn't actually drive with missing mounts but for changing them with it on stands it's OK.
Edited by Dan, 02 April 2007 - 07:14 PM.
#6 Spannermonkey6464
Spannermonkey6464
  • 587 posts
Posted 02 April 2007 - 07:35 PM
Brill cheers dan, tought it best to check before starting as is my only transport atm :) cant wait 4 day weekend :xxx:
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 02 April 2007 - 11:32 PM
I meant to say, for the toe board mounts do one side at a time if the frame or engine isn't supported. Not really dangerous but it'll make the mounts harder to fit if you pull out both at once as the gap will close up.
