Does someone make a hinged rear glass conversion kit? Will the rear glass need to be refitted with smaller/larger pieces, or can the OEM glass be modified to accept the hinge and lock mechanism? I assume the rear rubber window gasket will need to be replaced with a different type,. yes?
Thanks a million in advance!
Edited by ImagoX, 24 July 2007 - 02:39 PM.
