MegaSquirt / MicroSquirt
11 replies to this topic
#1 1979-mini
1979-mini
    Starting My Mini Up
  • 3 posts
  • Local Club: MOWOG, Border City Mini
Posted 25 July 2007 - 03:22 PM
Has anyone put EFI into their mini using MegaSquirt ?
I am planning on using Microsquirt when it becomes available in my 1979 mini. I am working on unique TB for this project. Just wondering if anyone else is doing it.
#2 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 25 July 2007 - 03:56 PM
me... :shifty: MS II V3.0 running EDIS and GSXR ITB'S
#3 v8mini
v8mini
  • 726 posts
  • Local Club: Minis on the run
Posted 25 July 2007 - 04:03 PM
I'm running megasquirt in my mini, but it ain't A series :shifty:
#4 mini13
mini13
  • 3,811 posts
Posted 25 July 2007 - 04:37 PM
this can be done as long as you mount the injectors a long way from the, ie in a similar position as the SU would be.
If you try to mount the injectors close to the head face you will run into problems.
on turbo minis there is a section dedicated to a new dedicated megasquirt code to enable port injection, if your interested have a look.
#5 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 29 July 2007 - 01:53 PM
Im an running VEMS which is a similar (but in my opinion superior) package on an SPi set up and it works very well.
Port injection set ups are difficult to achieve for reasons stated above.
I am currently looking into the Jenvy throttle boddies on an SU manifold, which is a good place to start from scratch.
Fuel injection is the way forward, its a steep learning curve with programable ECUs, but once you get the hang of it, you'll wonder why people harp on about carbs :thumbsup:
#6 Mini Mad James
Mini Mad James
  • 274 posts
Posted 30 July 2007 - 07:46 AM
Im planning on using megasquirt on my mini but im not sure how you go about mapping it :-
Can you do it yourself or do you have to take it to a rolling road?
#7 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 30 July 2007 - 01:12 PM
You can do it yourself (preferably with a wide band lambda) But its easier to take it to an RR especially if you dont have experience of setup an engine, unless you've got lots of time and dont need the car running straight off.
#8 Sprocket
Sprocket
  • 7,266 posts
Posted 30 July 2007 - 03:25 PM
If you do not want to spend money on RR sessions then i suggest you get the VEMS with onboard wideband Lambda and exhaust gas temp sensors. The remote LCD display gives real time lambda, exhaust ags temp, throttle position, manifold absolute pressure, igntion advance. That, with laptop data logging, and VE learn, makes it far easier to self tune.
I looked into both Megasquirt and VEMS when buying and opted for the VEMS, it is a far better packaged unit for the same price. The information availability was a bit of a mine field, but im over that now, so if you do take VEMS into consideration, i'm only willing to help.
I will be making up an adapter loom for plug and play with the VEMS and standard SPi loom for a friend, so all the difficult bit are taken care of.
#9 dn89mini
dn89mini
  • 32 posts
Posted 30 July 2007 - 06:42 PM
I have the Jenvey setup with Emerald K3. Still building the rest of the car but the engine is running great and it is so much fun to tweak the car using your laptop. I also have the Innovate LC1 wideband as Sprocket mentions, a lot easier to configure when you have real time data.
Edited by dn89mini, 30 July 2007 - 06:43 PM.
#10 Bill USN-1
Bill USN-1
  • 260 posts
Posted 31 July 2007 - 01:42 PM
I built mine with a stock SPI manifold for now, but chose the GM factory ECM and tune my own chips for it.
No real difference from an aftermarket ECM. Just a little cheaper and more plentiful in the US!!
MS may be a future option if I go with a power adder.
#11 Robanzac
Robanzac
  • 15 posts
Posted 19 August 2007 - 11:34 AM
Bill - are you using reffering to Kalamker by any chance?
#12 1979-mini
1979-mini
    Starting My Mini Up
  • 3 posts
Posted 06 September 2007 - 01:53 AM
Well, I've ordered my Microsquirt. Should have it in a couple of days. I will wire it up for ignition first and then play around with the fuel side of things later. If anyone has MSII running on their A-series, could you publish your VE tables, etc, so I have a starting point?
Thanks.
