Lazer cutting...
17 replies to this topic
#1 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 29 July 2007 - 05:54 PM
Is there anyone on here who works as i signwriters or something that can lazer cut perspex?
All im after is a pretty small bit of 3mm thick clear or smoked if poss perspex cut perfectly, iv done a proto with the jigsaw and etc to make sure my measurments are right and i kno what i want now.
If you can help i will let you know exactly what im after.
cheers
Mark.
Edited by screech, 29 July 2007 - 05:55 PM.
#2 redhotmini
redhotmini
  • 1,607 posts
Posted 29 July 2007 - 08:38 PM
have you tried a glazing company? i know shaws glass in horsham can do that if you ask nicely enough. its worth an ask!
#3 screech
screech
  • 3,136 posts
Posted 30 July 2007 - 10:30 PM
I was more thinking of someone with one of the computer Rolant Cad Cam jobbys or similar, cant see glass places have one of them.
Anyone?
#4 Ollie180
Ollie180
  • 2,781 posts
  • Local Club: Sasmog.co.uk
Posted 30 July 2007 - 10:32 PM
there is place in cowfold next to my mates garage that does like all plactic and stuff il ask him if they do cuting and stuff im sure they must do its on the site wher 16vmini shop is so duno if he will no
#5 screech
screech
  • 3,136 posts
Posted 30 July 2007 - 10:45 PM
Well you kno what sort of thing i need to if u can ask :-
#6 screech
screech
  • 3,136 posts
Posted 12 August 2007 - 04:12 PM
bump
#7 Ethel
  • 26,029 posts
Posted 12 August 2007 - 04:20 PM
Who was knocking out the poly carb ignition sheilds? They looked like they may have been lasered.
I know where there's a small cutter but not sure I can get my hands on it at the mo.
#8 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 12 August 2007 - 05:38 PM
CNC cutters and Laser cutters cannot cut from patterns - they will need an electronic drawing in DWG, DXF or EPS format.
in your area try the following :
www.stanleyplastics.co.uk - pretty good
www.cnc-it.co.uk - very good
upload me a sketch of what you want and I'll draw it up in autocad for you.
#9 screech
screech
  • 3,136 posts
Posted 12 August 2007 - 05:50 PM
Yea i realise this cheers.
o0o0o il make a drawing and let you kno, cheers
mark
#10 Gazz
Gazz
  • 164 posts
Posted 12 August 2007 - 05:59 PM
I could do it for you at school. However.. that wouldn't be until we go back in sept =/
#11 schneill
schneill
  • 127 posts
  • Local Club: Tyred And Exhausted
Posted 13 August 2007 - 08:54 AM
My dad does tshirt printing, he's got some signwriting program thats linked to a plotter to cut the designs out of vinyl. You just trace the logo that you want, hit go and this little knife thing does its thing then all you have to do is take the vinyl off that you don't want. In much the same way, i could put any vinyl (sticky vehicle vinyl for example) through this and get it cut, so door numbers or anything are easy. The point i'm trying to get at is that i have the tracing program that works in .eps format, which means you could take the file to a laser cutters. I've never used it for precise measurements and stuff but i'm sure it can't be too hard. You can also do .eps format stuff in adobe illustrator. I could give tracing it a go, you'd just have to find the laser cutters then?! Schneill
#12 CharlieBrown
CharlieBrown
  • 6,587 posts
Posted 13 August 2007 - 10:39 AM
MiniMadMe, might be able to help you out. PM him. :xxx:
#13 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 25 September 2007 - 05:35 PM
Yello, sooooo, what is it you need then?
I have access to a CNC cutter, but I don't know how neat it will cut polycarb. It should be OK, but I'd have to test it.
You got any sketches or owt?
#14 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 25 September 2007 - 05:36 PM
Ooh and it's LASER by the way, it's an acronym! :dontgetit:
#15 frankiebateman
frankiebateman
  • 3,288 posts
  • Local Club: NWMC
Posted 25 September 2007 - 05:40 PM
Go on ebay and loads of people do it on there because ive had it done :dontgetit:
