SMITHS OIL GAUGE LEAK
15 replies to this topic
#1 karlos_junior
karlos_junior
  • 176 posts
Posted 29 July 2007 - 09:41 PM
Hi there.
I have just finished my new dash (pics as soon as I fix this!) and the oils gauge keeps leek from where the line buts upto the gauge. the way it work is its just metal on metal that is tighted togeter by a nut over the top of it (its rather standard) anyway I got oil all over my foot while going on my IM FINISHED YEPPIE drive........ stink. so, I got a washer and some RTV and pluged that bugger up good, and it lasted half an hour.........doble stink, anyone got any ideas how the heck I can stop it from leaking?!?!?!?!?!?
thanks in advance...........
#2 karlos_junior
karlos_junior
  • 176 posts
Posted 29 July 2007 - 09:43 PM
...............STANDARD SMITHS WITH OIL LINE sorry, forgot to mention that...........
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
PTFE tape.
#4 karlos_junior
karlos_junior
  • 176 posts
Posted 29 July 2007 - 09:48 PM
excuse my ignorance...im from the south hence the inbreeding.........
what is PTFE tape?
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 July 2007 - 10:00 PM
Plumbers teflon tape, used for sealing threads. Three wraps of it around the thread on the gauge in the same direction the nut is tightened, add the correct washer and tighten the nut. Make sure not to use an excess of tape or bits of it will end up in the gauge, but you may have already killed the gauge anyhow if some RTV has got into it. RTV isn't for sealing threads.
#6 jonny d
jonny d
  • 1,148 posts
Posted 29 July 2007 - 10:08 PM
Had the same thing happen to me got some fibre washers at a show and that fixed it pipe must be tight
though, hope this helps
#7 karlos_junior
karlos_junior
  • 176 posts
Posted 29 July 2007 - 10:36 PM
yea thanks jonny D. I got a fiber washer on there too as well as RTV, got none in the pipe, still leaked........ I dont see how tape will help as its not the thread that its leeling from, will try a combo of all three thing unless anyone has any other ideas..... thanks guys for the help...
#8 Jupitus
Jupitus
  • 1,479 posts
  • Local Club: Breathemini
Posted 30 July 2007 - 11:20 AM
I'll second the PTFE tape - I had exactly the same issue.
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 30 July 2007 - 11:57 AM
The seal is supposed to be between made by the fiber washer. If your fiber washer is intact, look carefully at the fitting on the end of the oil pressure line. Perhaps it has a burr or it is cracked.
If the STANDARD oil line end fitting (from Smiths) has been replaced (and they often are once the fiber washers have been lost), then the fiber washer will not help and you'll need the Teflon tape mentioned above. You can use a standard 1/8NPT female to tube compression fitting on the Smiths gauge sealing the threads with Teflon tape.
#10 karlos_junior
karlos_junior
  • 176 posts
Posted 30 July 2007 - 09:55 PM
THANKS EVERYONE.
I will let you know how it goes, gonna tape that suka up real good....pics of dash in a few days
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 31 July 2007 - 12:22 PM
Good luck but remember if this still has the standard Smiths fitting on the end of the capillary tubing, you're going to need the fiber washer or similar. No amount of tape will completely stop the leak without the fiber washer when the standard Smiths fitting is on the tubing.
#12 karlos_junior
karlos_junior
  • 176 posts
Posted 14 August 2007 - 12:40 AM
Hi there.
Have complete fixing the leak and it no longer leak so YEPPIE...
now for the retarted question of the day!
My oild gauge im sure used to stay constant at 55
but now at ideling it drops to forty and picks up to about 60 on accelerating. Is this normal??
Thanks heaps.....
#13 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 14 August 2007 - 12:50 AM
I have started to dislike the oil pressure question because everyone has higher oil pressure than I do.
Answering the oil pressure question is sometimes difficult. I like to completely describe the situation. A cold engine will have higher oil pressure until the oil warms and thins. If your relief valve is doing its job, yes, something around 60 psi on a cold engine is OK. After you've been driving the car for a while you need to better describe the conditions at which you observe the oil pressure. For my car, when it has a hot engine idling at 800-900 RPM it has about 35-40 psi. As you increase the revs, the oil pressure will go up.
The short answer to your question would be, yes, your oil pressures sound normal and acceptable.
Edited by dklawson, 14 August 2007 - 02:32 AM.
#14 karlos_junior
karlos_junior
  • 176 posts
Posted 14 August 2007 - 01:19 AM
ha ha ha
thank you very much.....
#15 Big_Adam
Big_Adam
  • 7,435 posts
Posted 14 August 2007 - 08:26 AM
Yep, mine dose it too.
