right having serious thoughts of selling, for various different reasons....
description below....
Bodywork.
resprayed in black, original white roof - GOOD quality paintjob, flatted etc,
group 5 arches
Removable steel front - professionally fitted - good fit, is hidden well.
All chrome exterior parts.
Suspension.
Has also been set up - 1.5* neg cambre on the front, 1* on back, 3mm toe in on the back, (cant remeber what front was, also have forgotton the castor...opps)
Hilos
Adj Bottom arms
Adj Tie rods
Adj Camber rear brackets
Kyb Dampners
Brakes.
Cooper s discs and drive flanges
Alloy 4 pot calipers
Goodridge Braided hosing
Rear brakes adj bais valve
Mk1 Master Cyclinder
Internal brake line route
Wheels.
10x6 Revolution Alloys
Yokohama 008 tyres
Interior.
Coubeau Forza Seats
custom mounts
Brushed Alloy 3 clock dashboard
Extended and lowered steering colum
Moutney 14" steering wheel 1.5" dish
Ricco 3" Fia aprroved Harnesses
KAD Genuine Quickshift - lift collar
Rear doorbins and seat lip cut away
2x 10cm sony speakers in dash
2x 17cm jbl speakers in parcel shelf
Engine.
Professionally Rebuilt
1275 Gt Pre a-plus Block bored 60thou to 1330 Standard metro +60thou pistons
Metro Head Ported and polished - customized, to equivalent of stage 3/4
SW5 Camshaft
1.5 Swiftune RollerRockers
Adj swiftune alloy vernier duplex
Lightened+balanced Flywheel
Balanced crank
Orange Clutch plate
Pre verto clutch
Center oil pickup in gearbox
Cross-Pin Diff
Close ratio gears
Rebuilt Gearbox
3.44 Final drive
1.75 hs6 carburettor
Lcb manifold, Rc40 exhaust
Electric Fuel pump
Underbonnet.
Oil and water catch tank - custom - very unique
mk1 washer liquid bottle
alarm speaker
Alarm.
Sola-Alarm Motocycles alarm system
Thatcham insurance approval category MC 1
has 2 imobalisers, and other security features im not listing here lol
The car made 107bhp at baldwins dyno 2 months ago, at the end of bedding the engine in.
for people that want to know, it keeps up with a fiesta st till about 65 - 70
I spent 15 months doing the car with my uncle....
been driving it since april 12th - not broken down once...
I removed alot of rust, by either treating the light stuff, or cutting it out and welding in a new piece.
new front inc a panels
new drivers door
new n/s outer sill
Everything was stripped, cleaned and painted, the bulkhead was totally stripped and painted. boots been sprayed. all the sus arms, brackets, everything has been cleaned/wirebrushed then painted.
Top and bottom Balljoints replaced with new ones, as were front and back wheel bearings
So whats it worth ???
Thanks Dave
Edited by Mini-Dave, 01 August 2007 - 04:22 PM.
