Trailer wheels!
15 replies to this topic
#1 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 01 August 2007 - 10:15 PM
Ok... so I often see trailer with mini wheels on, and a lot of New trailers these days are fitted with Wheels that have the Same PCD as the mini wheel.
Some of these steel wheels have bigger dishes than for example; the 4.5" reverse rim, Triumph wheels (i think Pie had 12" steels on his shlag as they had a bigger dish to them)
What's stopping us buying some nice 6x10/5x12 or whatever deep dished steel wheels meant for trailers and slapping them on our minis?
Are they built to take the weight and different stresses of being driven, or are they trailer only wheels and can only support limited weight etc.
Not something i'm thinking of doing,... but just a though that's been in my head.
:kiss:
#2 Jammy
Jammy
  • 25,397 posts
Posted 01 August 2007 - 10:24 PM
My immediate thought is that they won't be speed rated very high.
#3 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 01 August 2007 - 10:25 PM
yep this is the kind of thing i was thinking,....
#4 mike.
mike.
  • 6,176 posts
Posted 01 August 2007 - 10:58 PM
Yeah it'd be the speed rather than the weight i think. The trailers with 12" wheels will usually be the heavy load trailers so the weight wouldn't be a problem i don't think.
Also im not sure how well those wheels are designed for cornering, not sure if they'd be any good at taking the forces of a mini thrashing around corners?
#5 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 01 August 2007 - 11:17 PM
this was my main thinking... the cornering, if you were to shod them with decent tyres... wht would happen?... It's not really important though. I was just spurting some of the useless thoughts i have each day out :kiss:
#6 mini_kev
mini_kev
  • 716 posts
Posted 01 August 2007 - 11:27 PM
isnt it the tyres that are the important factor when it comes to cornering and speed factor? If so i cant see them being a problem
#7 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 01 August 2007 - 11:29 PM
my friend has 10x6 wellers on his trailer
#8 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 01 August 2007 - 11:30 PM
We're on about fitting wheels made for trailers onto minis, not mini wheels onto trailers.
Or is there any difference? hmmmmm
#9 mini_kev
mini_kev
  • 716 posts
Posted 01 August 2007 - 11:33 PM
id imagine that if a mini wheel can perform a trailer wheels job then why cant a trailer wheel perform a mini wheels job?
#10 mini93
mini93
  • 8,615 posts
well just sayin that it works both way round, on the actual steel wheel before fitting to a mini check the welds, wellers are seam welded all the way round but normal steels are welded in just a few points to hold the centre in. id perfer seam welded
of course if you put more weld dont let it get hot of it will buckle
#11 Grayedout
Grayedout
  • 901 posts
Posted 02 August 2007 - 07:53 PM
You may find the offset is completely wrong !!!
#12 CR#
CR#
  • 48 posts
Posted 02 August 2007 - 08:16 PM
I’m sure I remember reading somewhere that the cooper s reverse rims centre is only held to the outer rim by four steel rivets? I’m sure that the wheels would be fine, but that’s jus imo.
#13 scottyegg
scottyegg
  • 394 posts
Posted 02 August 2007 - 08:28 PM
only one way to find out
#14 lewis
lewis
  • 2,322 posts
  • Local Club: Mini Club Jersey
Posted 02 August 2007 - 09:02 PM
i thought about this too when i was in my local automotive shop, some of them had a really deep dish!
who wants to give it a try then? lol
#15 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 02 August 2007 - 09:07 PM
yup. we looked at this (me sqweaka and miniboo). theres 4 spot welds or riveted welds on them
Edited by Jordie, 02 August 2007 - 09:08 PM.
