HELP fitting a Morris 1300 engine into 74 mini
4 replies to this topic
#1 cougar
cougar
    Starting My Mini Up
  • 4 posts
  • Local Club: nil
Posted 02 August 2007 - 12:22 AM
Hi All
Need Help urgent. Can a 72 Morris 1300 (rubbered cross) Engine and box fit into a 74 mini 1000.
If so what needs to be changed
Have to get car on the road asap have dead 1000 and great 1300 motors and boxes and nill money :kiss:
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 02 August 2007 - 08:17 AM
If it's a remote gearbox, check the clearance of the bolts which hold the remote to the gearbox. In the ADO16 variant they are attached with horizontal bolts but with the mini they are attached vertically..
If it's rod change then there are no issues
The other thing is that the 1300 engine will have a silly short diff in it (3.6,3.7 or 4.1) so it may be worth taking that out, replacing with something like a 3.4 and at the same time replace the output shafts for pots and ditch the crucifix.
Or the alternative is (as long as it's not a 3 synch ) put the existing mini gearbox on the 1300, as there's no difference between them.
Edited by GuessWorks, 02 August 2007 - 08:18 AM.
#3 cougar
cougar
    Starting My Mini Up
  • 4 posts
  • Local Club: nil
Posted 03 August 2007 - 01:51 AM
Can I swap the mini diff straight into the 1100/1300 housing?
And does the remote gear off the 1100/1300 fit into the minis rod change sub frame??
Thanks for your help :kiss:
Edited by cougar, 03 August 2007 - 02:08 AM.
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 August 2007 - 08:21 AM
The subframes are the same, but if the mini is designed for a rod change, then a remote gear change will NOT fit without modifications to the tunnel. In this eventuality, swap the box from the 998 onto the 1300...
#5 Chrome_GT
Chrome_GT
  • 78 posts
Posted 30 December 2007 - 09:45 AM
How did the conversion go?
