Annoying intermittent fault
12 replies to this topic
#1 mini_morley
mini_morley
  • 674 posts
Posted 03 August 2007 - 08:32 PM
Right:
The other evening i was out in my car. I had jsut filled up after running quite low. I was driving up a steep hill, over speed ramps (damn things) when the car started spluttering, and the was a loss of power. Stopped, and after have a poke round, called the AA out. THe man reckoned it was the points, took the dizzy cap off, and yes, they were a bit knakkerd (however the engine hadnt been running rough, so i had not looked at them, thinking all was ok) . he cleaned them up and we got home. I brought a replacment dizzy cap, rotor arm, points and condensor, and fitted them today. I ran the car up on the drive, revved it a bit, and it seemed fine, not of the sputtering. Earlier i wen for a drive. I went from where i live to the next town, about 7 miles, and drove round the town. I then had to wait at a set of traffic lights for about 2/3 miniutes. Upon pulling away, i had the same problem. I stopped and let the car cool down for about 5 mins, then went again. THe problem kept coming and going as driving, despite the different remidies i tried (choke out, driving gently, drivng hard).
Now i know my timing isnt perfect, which probably doesn't help, but can any body help? I want to get this sorted ASAP, please.
Morley
Edited by mini_morley, 03 August 2007 - 08:32 PM.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 03 August 2007 - 11:01 PM
Could be the coil or a fuel filter/system blockage problem (I am NOT saying this because you let the tank run low, that's another urban legend).
Could be other things too though including just a general tune up.
Edited by Dan, 03 August 2007 - 11:10 PM.
#3 Ethel
  • 26,074 posts
Posted 03 August 2007 - 11:09 PM
Coil or plugs leads are a fair bet. Shame Argos don't do Mini spares or you could try the lot 'n take back the bits you don't need :lol:
#4 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 04 August 2007 - 12:21 AM
Hmmmm, all the suggestions sound pretty likely... though it could also be that your Float and needle valve need changing.
#5 minislapper
minislapper
  • 1,957 posts
Posted 04 August 2007 - 07:25 AM
Have you got the correct coil fitted?
#6 Leonard
Leonard
  • 784 posts
  • Local Club: mini rebels
Posted 04 August 2007 - 03:51 PM
maybe the timing is too advanced. try 98RON fuel see of it helps
#7 mini_morley
mini_morley
  • 674 posts
Posted 04 August 2007 - 07:28 PM
Ironicly i had just filled up with Optimax (well the murco equivilent), i tend to put a tamk of high octane (usually optimax) every 3 or 4 tanks. I put new HT leads on this evening and went for a drive, and the problem came back after about 10/ 15 mins of quick (dual carrigeway) running, then turning onto a back road. It was solved by letting it cool down a bit, then driving gently wiht the choke fully out, but after about 10 mins or so it returns, and i ahve to do the same thing, so i think it might ba a carb problem.
Next on the list is a new needle, fuel filter (it hasnt been done recently anyway), and coil, but i might book it in for tuning somwhen soon aswell, as its not perfect.
Thanks for the help, any more greatly appreciated!
Edited by mini_morley, 04 August 2007 - 09:46 PM.
#8 mini_morley
mini_morley
  • 674 posts
Posted 05 August 2007 - 04:08 PM
bump
#9 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 05 August 2007 - 09:39 PM
Probably time to get in touch with these people then: -
Burlen Fuel Systems link
#10 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 05 August 2007 - 09:45 PM
does it do this everytime you put in the optimax, if so stop doing it, its a higher octane so if your going to run your car on this you will have to adjust your timing accordinglly, or just use ron95, with out any problems
#11 mini_morley
mini_morley
  • 674 posts
Posted 05 August 2007 - 09:59 PM
Its never done it before, and ive putting optimax in more than once, its only since the last time i put it in (wich was murco version). Im going to strip down my carb this week to give it a clea nup, and replace the needle while im at it, see if that helps. I dont really want to be buying a new carb...
#12 mini_morley
mini_morley
  • 674 posts
Posted 07 August 2007 - 04:05 PM
All sorted, turns out it was the vacuum advance pipe was cracked.
Thanks to eveyone who gave me advice on the matter!
Edited by mini_morley, 07 August 2007 - 04:06 PM.
#13 sheree&the-gt
sheree&the-gt
  • 909 posts
  • Local Club: Leeds MOC
Posted 07 August 2007 - 04:31 PM
this will be the problem, common fault
ben x
