Replacing the outer weather strips
Posted 04 August 2007 - 06:11 PM
http://gbcarparts.co...SealDoorToGlass
What I want to know is what is the safest way to remove the current seals, as mine seem pretty stuck on there. Any advice?
Posted 04 August 2007 - 06:21 PM
I have a problem with water pouring in under my door cards, so I pulled them off and duct-taped up the holes. I also noticed that my outer weatherstripping isn't really making contact with the windows that well, as well as one of the black caps on the end of them is missing, so I was thinking about ordering this set of seals:
Slid inside the slot/groove of each seal between it and the door there should be a couple, or several small clips which hold the strip on so it doesn't slide off when you wind the window up.
If you wind the window all the way down, and try lever the outer ones out from the inside with a small flat head screwdriver that's probably the best way. Worked for me
Edited because of spelling I'm useless today!
Edited by yorkshirechris, 04 August 2007 - 06:22 PM.
Posted 04 August 2007 - 08:22 PM
