Exhaust Cat Laws
Posted 07 August 2007 - 10:10 AM
Posted 07 August 2007 - 11:49 AM
Edited by taffy1967, 07 August 2007 - 11:51 AM.
Posted 07 August 2007 - 12:18 PM
wayne
Posted 07 August 2007 - 12:52 PM
Posted 07 August 2007 - 01:06 PM
In fact I've heard that there's a little section at the back of every MOT testers hand book which points out this fact.
I've also heard that early injection Coopers don't need a cat fitted too and I think that's where the before 1992 rule stands.
So if you have any problems with the MOT tester, just get him to check the back of his book.
Edited by taffy1967, 07 August 2007 - 01:07 PM.
Posted 07 August 2007 - 01:16 PM
The main limits for that (IIRC) are:
CO2 <3.5%
HC <1200ppm (parts per million).
That's the same as a test for a carb or injection car first registered between 1st August 1984 to 31st July 1992 (again IIRC) which aren't fitted with cats. It's a grey area. It's basically because there is no control loop as such for the carb equipped mini, like there is on other injection equipped marques with a cat.
All of that being said, I stopped testing nearly 8 years ago. I can't remember any note in the back of the tester's handbook about carb equipped minis etc. But that information above is the best that I can remember.
Posted 07 August 2007 - 01:37 PM
Anyway the only hassle I had was when ATS fitted my back box upside down and the manager of Quick Fit insisted that I needed a cat and should buy a new O/E exhaust system from them because after market jobs are rubbish.
So naturally I stay well away from both of these monkey ran companies now!
Edited by taffy1967, 07 August 2007 - 01:40 PM.
Posted 07 August 2007 - 06:50 PM
