lowerd shocks
11 replies to this topic
#1 MINI jon
MINI jon
  • 68 posts
Posted 09 August 2007 - 11:48 AM
if i were to just fit lowerd shock absorbers on my mini will it make my mini lower?
thanks
#2 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 09 August 2007 - 11:54 AM
thanks
No.... and they wont fit either.
Shocks have nothing to do with the ride height on a mini,... To go lower you need to get some Hilos which effectively give you an adjustable alloy trumpet rather than the solid one as standard. When You wind this adjustable trumpet down,... the car's ride height goes down.
If you're on standard shocks and go very low, you will then need to get lowered shock mounts so that you can fit some lower shocks that are also stiffer. Else you'll be bouncing off the tarmac etc.
Edited by Retro_10s, 09 August 2007 - 11:55 AM.
#3 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 09 August 2007 - 05:05 PM
lowered shock mounts are so that you can lower your car and still use your normal length shocks.
lowered shocks are for lowered cars with std shock mounts, and are usually adjustable so they an be as soft or stiff as you want them to be.
change one or the other, not both.
the bit about the hi-lo's is right tho :shifty:
#4 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 09 August 2007 - 05:07 PM
my apoligies, I was under the impression that the standard shocks became too large once lowered mounts were fitted, hence the need for smaller shocks.
#5 Ethel
  • 25,996 posts
Posted 09 August 2007 - 05:32 PM
To be a lil bit picky hilo's aren't the only way to lower your Mini and swapping shocker mounts only really applies to the front end.
#6 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 09 August 2007 - 08:53 PM
Ok then, you could also cut the alloy trumpet down rather than fit Hi-los, or get softer cones, You could fit coil overs and do it that way,...
#7 Ethel
  • 25,996 posts
Posted 09 August 2007 - 08:56 PM
.....don't forget filling your boot with cement 'n letting your tyres down :shifty:
#8 Jammy
Jammy
  • 25,397 posts
Posted 09 August 2007 - 09:05 PM
And you can get a big heffa to lie across your bonnet! :shifty:
#9 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 09 August 2007 - 09:09 PM
Jammy i didn't know you were for hire :shifty:
#10 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 09 August 2007 - 09:32 PM
lol
#11 minibarmy
minibarmy
  • 493 posts
Posted 10 August 2007 - 01:19 PM
lol
What happens if you fit both lowered shocks & lower shock brackets with Hi-lo's to reduce the ride height?
#12 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 10 August 2007 - 04:01 PM
Then you can now lower your car so much it might not pass an MOT as it can't get on the MOT ramps.
** edit though it'll probably be running on bumpstops by then,.... NOT good. **
Edited by Retro_10s, 10 August 2007 - 04:01 PM.
