Posted 10 August 2007 - 08:47 PM
Voltmeters only have two connections (excluding the light). If you are blowing fuses with the volt gauge, you have something wrong with the gauge. Using jumper leads try connecting it directly to the battery... but do it this way.
Connect wires directly to the battery. Some distance away from the battery, connect a single jumper leads to one gauge terminal. Tap (not hold... tap) the second wire to the gauge's second terminal. If you get a shower of big sparks, don't use the gauge, take it back. If the gauge works, you've got some other problem. (Perhaps earlier you wired the gauge between two live circuits instead of between one switched circuit and earth).
In general it's a bad idea to wire any gauge, particularly a Smiths volts gauge, directly up to the battery. The Smiths volt gauges pass a lot of current and you'd quickly drain the battery if you didn't use a switched circuit.
