boost gauge fitting
5 replies to this topic
#1 mini_jim
mini_jim
  • 183 posts
Posted 10 August 2007 - 08:04 PM
where do i connect my boost gauge ?
can i install a t-peice in the tube from the top of the dump valve that goes the to spacer on the manifold and run it from the t peice ?
jim..
#2 Ethel
  • 26,074 posts
Posted 10 August 2007 - 09:16 PM
I'd run it from the manifold, especially if it also shows vacuum. Certainly don't plumb it in to anything that leaks air i.e. if you're using a bleed valve.
#3 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 12 August 2007 - 10:38 AM
Ideally it's supposed go to the inlet manifold, on its own connection. Though i have mine fitted to the vacuum advance connection, as i dont use this for the dizzy. It seems accurate enough fitted here & has been like this for 5+ years.
#4 mini_jim
mini_jim
  • 183 posts
Posted 12 August 2007 - 01:00 PM
i have been told its ok to plumb the boost gauge into the air pressure sensing hose that runs to the fuel pressure regulator from the plenum ?
or is that complete bubbles ?
jim. :xxx:
#5 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 12 August 2007 - 04:03 PM
you can, but you'll get a better idea of what your engines seeing if its off the inlet manifold.
#6 mini_jim
mini_jim
  • 183 posts
Posted 13 August 2007 - 01:47 PM
ok cheers will do.
jim.. :D
