Mini doesnt want to take the load
Posted 12 August 2007 - 08:48 AM
My mini is a bit ill at the moment. When she idle she is ok, but as soon as I try and drive with her, she threatens to cut out, or 'stutters' so much that she threatens to cut out, and at one occasion she did just die on me.
I've serviced the carburetor, and everything there is squeeky clean, cleaned the airfilter, checked that the petrol pumps okey, cleaned the distributor cap ...
I desperately need her driving
Could anyone help me please?
Posted 12 August 2007 - 12:05 PM
Posted 12 August 2007 - 12:06 PM
Posted 12 August 2007 - 01:53 PM
Does using the choke make any difference?
That just push up the revs ... but as soon as I try and drive nothing ... or if I try and rev nothing...
just keeps trying to quit and die
Posted 12 August 2007 - 01:54 PM
Did you replace the Float and needle valve on the carb?
didnt replace the float, but replaced the needle valve, made sure that the float wasn't damaged though
Posted 12 August 2007 - 02:17 PM
Posted 12 August 2007 - 02:21 PM
Did you put some oil back in the carb dashpot after the service?
Yes I did, not allot but enough to keep it nice and oiled
Posted 12 August 2007 - 02:55 PM
On top of the carb under the black screw in cover you need to put in some oil, do a search or check haynes on what spec oil.
I didnt mean oil as in general lubrication of mechanism's
Posted 12 August 2007 - 03:36 PM
Posted 12 August 2007 - 04:38 PM
You fill the dashpot up to the 'shoulder' of the spout... use the same oil as you used in your engine.
I did do this when I put the carburetor back in .. but thanks
Posted 12 August 2007 - 04:40 PM
Just in case, you might have mis understood
Thanks I did do this when I put the carburetor back in yesterday
Posted 12 August 2007 - 04:44 PM
but she is only marginally better than before I serviced it
Posted 12 August 2007 - 09:18 PM
cheap stuff as well, doubt its the carb causing your problems
wayne
Posted 12 August 2007 - 10:25 PM
Posted 13 August 2007 - 05:07 AM
Thanks for that, when I serviced the carburetor I cleaned within an inch of being new... Being a girl, wanting to fix her car, my carburetor looks new , I;m gonna try the above, replace the points .. and if I get pissed off enough mbe replace the whole distributor cap *sigh*my mini did that.. what mine was, the carb sucked in a big bit a metal from somwhere and it got jamed half way in the intake, so sound like its beening strangled to me.. look long and hard for somut in your air intake
Pity I love the Beastie so much ... or I would have had one amazing bbq this weekend *G*
