Hesitate at 2300 to 2500 rpm
1 reply to this topic
#1 seria
seria
  • 77 posts
Posted 15 August 2007 - 10:45 AM
1992 1275 Rover Mini Cooper SPI
The car start without problem. Idle not really steady. It moves around 800 to 900 rpm and occasionally almost die. On acceleration there is a number of flat spot at around 2300 to 2500 rpm. This occur on all gears. However the engine rev without any problem. If I really put the accelerator down, there is no flat spot on all gears. What do i need to look out for please help. All vacuum hoses just change recently.
Thank you.
#2 griff2
griff2
  • 207 posts
  • Local Club: east coast minis/ ni-minis
Posted 18 August 2007 - 10:56 AM
Thank you.
hi
not sure if this will help but this happened to both me and my mate after we messed with the injector (put a bigger one in lol) after changing it back car ran sound again at all rev range,also my car ran like a bag of poo for a while after lots of messing i found it was the small vacum pipe had a small hole in it (the black on to the map sensor) once replaced £1.20 from local car shop it solved everything no more hunting at idle and goes throw the rev range sound once again
cheers
griff
