Taking Engine Out
12 replies to this topic
#1 dave87
dave87
  • 169 posts
Posted 23 August 2007 - 09:29 PM
hey all
how does the engine come out is it easy?
thanks
#2 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 23 August 2007 - 09:32 PM
if you kow what your doing then still no! lol
#3 dave87
dave87
  • 169 posts
Posted 23 August 2007 - 09:37 PM
lol oright ok, how long will it take? anything i can use to take it out?
cheers
#4 minislapper
minislapper
  • 1,957 posts
Posted 23 August 2007 - 09:58 PM
Is this post for real? Have you bothered to buy a manual? Do you have any tools? Have you done a search to find out more information?
If your knowledge is as limited as your posts imply then it will not be a quick job.
#5 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 23 August 2007 - 10:06 PM
ok we are frendly and we dont need to use this tone
as for taking the engine out there are a few things you need to consider first.
1, do you have an engine hoist, and facilities to reove the engine alone
2 if not consider removing the subframe and engine as a complete unit.
3 why do you need to remove the engine in the first place, most jobs can be done with the engien in situ.
answer these question and we can give you more answers
#6 dave87
dave87
  • 169 posts
Posted 23 August 2007 - 10:09 PM
ok keep your hair on it was only a question, its a technical and problems section aint it??? and this is my search to find out more information i dont go round pulling engines out everyday im a painter no a machanic so i thort id ask for some advice if thats ok with you please let me no if its not >_<
#7 Globule
Globule
  • 1,134 posts
Posted 23 August 2007 - 10:10 PM
Also you need patience, alot of the nuts etc could be rusted so need some encouragement to move, or may be in awkward places to reach! Theres always little complications but its fairly simple as it is just nuts and bolts securing the majority of it so you dont need to be an expert but certainly a manual is needed if your not too knowledgeable on how it all works!
#8 dave87
dave87
  • 169 posts
Posted 23 August 2007 - 10:12 PM
need to remove it to paint engine and engine bay dont have hoist no
dave
#9 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 23 August 2007 - 10:20 PM
I think i would drop the engine out with the subframe as u will get all suspension/brakes ect out of the way also so u can do a better job of painting inner wings ect
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 August 2007 - 11:16 PM
Basically two ways, as above...
either engine out with a hoist, block and tackle, or piece of poly prop two strong blokes and a fence post ( don't let Health and Safety hear me saying that but I've done it all three ways ). This way the subframe stays in the car and therefore remains mobile...
or..
Drop the subframe, if all you need is access to the engine bay then I would do it this way... it also means you can get away with removing less from the engine, and you don't disturb engine mounts, driveshafts etc but you will need to disconnect the exhaust, gear linkage, brake system, clutch, remove carb / injection manifold, wiring and a few other bits and bobs...
#11 Ethel
  • 25,980 posts
Posted 24 August 2007 - 12:13 AM
You could do with a ball joint splitter for the track rod ends and a big socket (1 5/16) for the subframe tower mounts - you'll also need to disconnect a brake line and bleed the brakes afterwards.
#12 Grimmy@JHE
Grimmy@JHE
  • 759 posts
  • Local Club: tmf
Posted 24 August 2007 - 12:23 AM
this months miniworld has a guide to do it in a week end. its quite good.
blackpool hey? its not good is it.... live in bispham.
Edited by grimmy, 24 August 2007 - 12:24 AM.
#13 dave87
dave87
  • 169 posts
Posted 26 August 2007 - 05:42 PM
thanks for all replys and help, i will get someone to help me thats dont it before.
were abouts in bispham you live? thanks
dave
