Titan Roller Rockers
12 replies to this topic
#1 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 23 August 2007 - 11:11 PM
I have just got some Titan 1.5 ratio roller rockers.
I am dummy building up the head.
The standard A+ flange head nuts catch on the rockers.
I was thinking of turning down the Flange on my lathe. will this work?
One of the books I read lately suggested using old big end nuts and rethreading them to suit the stud thread.
However!!! I have no spare big end nuts. and I also dont trust myself to re thread such an important nut for the engine.
Anybody got a cunning plan/advice, or suggestions on someone helpful to phone
(I really should go to bed now or I will lie awake dreaming of Golden Rockers) >_<
#2 Ethel
  • 25,969 posts
Posted 23 August 2007 - 11:16 PM
I'm not clever enuff to claim this cunning plan as my own...
You can use big end nuts >_<
Think it explains it on the minispares techno blurb for their rollers.
#3 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,229 posts
  • Name: Simon Jackson
Posted 24 August 2007 - 07:49 AM
Yup thats right, but the S big end nuts!
http://www.minispare....aspx?pid=32705
#4 Kerrin
Kerrin
  • 1,056 posts
Posted 25 August 2007 - 07:41 AM
Great thanks.
My latest Mini spares parcel arrived yesterday!
Looks like there will be a new one on its way soon.
K :thumbsup:
#5 mini13
mini13
  • 3,810 posts
Posted 25 August 2007 - 10:17 AM
I'd turn the flange down.
#6 Kerrin
Kerrin
  • 1,056 posts
Posted 25 August 2007 - 01:18 PM
I have looked at turning the nuts down, but if I do just turn down the flange there is still a possibility that the widest part of the standard nut hex will catch.
So I think the multipoint nut is the best solution.
Shall I put them on all the head studs so I can use one socket to torque down the head, or are they the same size. I dnt mind buying 9 just making sure they will do the job.
However if they can hold the big ends together at 6k rpm they should be fine :thumbsup:
#7 Ethel
  • 25,969 posts
Posted 25 August 2007 - 02:35 PM
I'd stick with the flanged K nuts for the others. It's not like you'll be tackling a cylinder head removal armed with just one socket anyway.
#8 Kerrin
Kerrin
  • 1,056 posts
Posted 26 August 2007 - 10:04 PM
I tried turning down one of the flanged nuts this morning.
I dont think it is going to work the nut still overhangs the rocker pillar.
Unless the head nuts torque up exactly with the flats front to back on the head they may still catch.
So its back to the nuts as above.
I am going to put 9 on. I really cant be bothered changing the sockets on and off the torque wrench every time I move to the next stud while torqueing the head up!
All I need to do now is get a nice shiny rocker cover which will miss them. any suggestions?
Edited by Kerrin, 26 August 2007 - 10:04 PM.
#9 Ethel
  • 25,969 posts
Posted 26 August 2007 - 10:09 PM
MG Metro cover clears them
#10 Kerrin
Kerrin
  • 1,056 posts
Posted 26 August 2007 - 10:11 PM
Oh great! thats what is on the car. just needs a polish.
#11 Ethel
  • 25,969 posts
Posted 26 August 2007 - 10:20 PM
Nagging doubt:
Does a big end nut replace the head nut or the other nut on the rocker post???
Might be worth ringing and checking before you buy any.
#12 Kerrin
Kerrin
  • 1,056 posts
Posted 27 August 2007 - 12:14 AM
I dont think the rocker std nuts are a problem as they are a 1/2" nut. the washers may be in the way but I will make others fit or modify them.
More lathe time ;D
From the mini spares website I found they are included in a kit with the rockers. but had the same doubt.
I will PM Simon
I am going to dry build it all up on my spare block before I convert the car so no panic just yet
#13 Ethel
  • 25,969 posts
Posted 27 August 2007 - 12:20 PM
Just looked at mine (minispares setup), the S big end nuts do replace the head stud nuts - they just look so small in comparison!
