well here it is
here is the spec
Engine spec: 1399cc with 74mm pistons, kent 310 scatter cam, spade drive oil pump. Vernier timing gears, aldon race distributor. Ultra light steel fly wheel and lightened clutch with bronze pad friction plate. Race spec head built by gsc engineering with raised inlet ports steel manifold matched/dowled to head. Weber 45 carb. 3into 1 manifold. Twin rc40 exhaust.
Gearbox; 4 synchro straight cut box salisbury lsd with 4.3 crown wheel and pinion. Straight cut drop gears. 1.04 reduction ratio.
suspension; Hi-lo suspension on front with front roll bar adjustable camber arms . Gas shocks. Coil over shocks at rear. with 150lb springs.
Brakes; Tarox discs with carbon metallic pads.
Body work is in very good strong condition. Car has single bucket seat with harness. Full safety roll cage and electric cut off switch fitted externally. Car has removeable bonnet and boot lid on straps etc.
