Help Me! Get My Mini Set Up Please
matbmx
, Aug 29 2007 07:08 PM
10 replies to this topic
Posted 29 August 2007 - 07:08 PM
hi there i have just built my engine with the following spec-
1340 a series
276 cam
1;5;1 roller rockers
equivelant of a stage 3 cylinder head
weber 45 on 3 inch alloy inlet
ultra light flywheel
ap raing clutch
13 row oil cooler
i plan to have it rolling road setup but first i would like to get it run in .
i am using a weber 45 but is not jetted correctly and is heavilly over fuelling.
could any one supply a list of jets main and idle, air correctors, emultion tubes that i will need?.
i will then hopfully be able to get my mini running sufficiently to get in run in.
also does any one have any recomendations on who to buy the jets etc from?
many thanks Mat
1340 a series
276 cam
ap raing clutch
13 row oil cooler
many thanks Mat
Posted 29 August 2007 - 07:29 PM
find someone who has bench testing facilites and take the engine there, they will get it running sweet as a nut ready to be fitted. (or if already fitted, take to a rolling road)
I use a place called Pitstop in brize norton but, they're only 5 miles from me.
Posted 29 August 2007 - 07:40 PM
yes its already fitted, have you an adress for them?
Posted 29 August 2007 - 07:42 PM
the Vizard book has a rough jetting guide in it,I haven`t got mine here though!
Posted 29 August 2007 - 07:52 PM
any one got a copy of the page as my visard book is water damaged ?
Could try here:
http://www.lynxaelr1.co.uk/
Took my mini here. He jumped under the bonnet straight away to have a bit of a poke to see what may need doing. Tell him what you want done, time limit etc and away he goes. He's mini friendly as well.
Posted 29 August 2007 - 07:55 PM
thanks i have spoke to him already and am looking to get it rolling roaded there
Posted 29 August 2007 - 07:57 PM
Well he's fitting my new carb tomorrow, other one was broken. So i'll let you know what i think of the service.
Edited by schneill, 29 August 2007 - 07:58 PM.
Posted 29 August 2007 - 07:59 PM
that sounds good, thanks mate look forward to hearing about it.
Posted 29 August 2007 - 09:17 PM
looks like lynx will be much closer for you, but just incase, pitstop are at Viscount court, Brize norton. (little industrial estate at the end of the runway) and they build/ setup loads of miglia's so there are usually about 10 very high spec mini's there at any one time.
Posted 29 August 2007 - 09:21 PM
paying alot of money for something thatll never quite be right. I no mine will be running rich, so im gonna pootle down to southam next week to get it setup IN CAR.
Why did you only go for a 3" manifold mate? your kinda looking the weber advantage of straight induction... Had a chat to SMMC, Bill richards and maniflow about this. They wreckon if you fit those tiny manifolds you may as well stick with an SU
