help
Posted 26 January 2005 - 08:18 AM
'right first off ive just finished my system and had to do it at a budget so used the best stuff i could find 2nd hand and all works well. ive got some 4 inch mids in the doors, a 10inch JBL sub in the boot in an advised sized box powered by an alpine amp (1x100w rms bridged) all ran of an alpine cde-9828rb headunit.
anyway im nearly at the stage of thinking about an install for my project car (a mini) and trying to use my first system as something to learn from. my system i have now sounds good from inside the car but outside all that happens is i get loads of panel rattle from the boot and rear quarters. i think this is mainly down to the boot area being sealed but any ideas will be much appreciated.
for my project car ive found some door pods to fit 5 inch speakers so i will get these and seal them but im still wondering what to do bass wise. ive got an area under the back seats that has enough room for possibly 2 8inch subs but im not sure about the bass this will kick out. I know a 10 will fit in a box in the boot and im pretty suer a 12 would but i'd be getting very limited on the amount of space for the box. my 3rd option is to mount a 15inch sub against the rear bulkhead as my boot is a sealed unit but i wouldnt be able to fit a box in there. i would possibly drill some holes in the top of the parcel shelf to let air through?
please help me as i dont really know much at all about car audio except dont use 6x9's lol. thanks in advance, rob'
Posted 26 January 2005 - 11:45 AM
Posted 26 January 2005 - 02:16 PM
Posted 26 January 2005 - 02:47 PM
As for panels rattling, find where its rattling and stick some dynamat in there or brown bread or whatever ur selected sound insulation is. May take a while but its somet that could stop it.
Go for a good quality single 12" if you got a mix like that... and make sure you invest in some good components and amp to match... Go for some nice Fusion components with matched amp.. and maybe a nice kicker 12" with a 500w single channel digital amp.... that thing will certainly be nice.... with that u mite need some co-ax in the back to balance it a bit better.
Nick
Posted 26 January 2005 - 04:24 PM
Posted 26 January 2005 - 06:05 PM
no-matter what you do there will always be a rattle
Posted 26 January 2005 - 07:58 PM
Posted 27 January 2005 - 04:28 PM
Posted 27 January 2005 - 06:03 PM
are you keen on having more than one sub? if so then you can really go to town, have a pair of 8's for when you listen to your punchy dance/trance etc, and then switch over to two 15's!! when you want extremely loud results, i saw a guy with an FTO the other day, 2 15'' kicker subs in the boot, with the boot closed it vibrated my friends rear view mirror 6 cars away
Posted 27 January 2005 - 06:05 PM
MAKE YOUR WIRING NICE AND NEAT
you wouldnt believe how pap something looks when its untidy, especially when your gonna plough a bit of cash into this from what u say, good luck my friend
Posted 28 January 2005 - 12:47 AM
rob what i would do is have a 12" kicker in the boot, only one as there isnt enough air for two and then try to make something for the 8s under the rear seat, though you will have a job calculating the correct air mass behind the subs.
Another idea is to play with differnt boxes, a bassy sub can be made punchier with slightly less air and a ported box!
Posted 28 January 2005 - 01:27 AM
Posted 29 January 2005 - 10:08 PM
Posted 31 January 2005 - 04:03 PM
Posted 04 February 2005 - 02:57 PM
