Unleaded Head
Posted 05 September 2007 - 11:40 AM
I checked the engine numbers and it appeared the car was built running 4 star. Ok i thought, problem solved...but no
the previous owner emailed me and said the car ran on unleaded for all the 4 years she owned it. she never had a conversion but maybe the last owner did before her she had no idea... she was told at purchase it was unleaded.
so folks what do i look for to check its unleaded and if it was not converted and should be on 4 star... how in hell is it still alive. the engine ran pretty well once the choke is off and no knocks or bangs and no smoke????
HELP!!!
Posted 05 September 2007 - 11:49 AM
Posted 05 September 2007 - 11:53 AM
The only way to be sure if it has been converted is to remove the cylinder head and have a look to see if it has had hardened inserts fitted in the valve seats
ok and if it hasnt, what damage has been done?
Posted 05 September 2007 - 11:56 AM
If it was me I'd use it as an excuse to fit a flowed head
Posted 05 September 2007 - 12:00 PM
If it doesn't have unleaded valve seats it can run on unleaded perfectly fine but you'll be slowly eroding them and the day will come when it won't run very well on any petrol. The only way to be absolutely certain is to take the head off and look at the valve seats.
O dear, well ive no idea what a flowed head is... as im still learning about all this and to be honest exactly how easy is it for the novice to attempt head removal and replace, armed with haynes manual of course?
is it as simple as remove have a look and replace using new gasket and studs???
Posted 05 September 2007 - 12:03 PM
have you tried running it with leaded petrol? i know seems the obvious but if it runs better then perhaps its that?
i dunno im a novice
Posted 05 September 2007 - 12:08 PM
we only drove it 1 mile, it drove ok considering it had not been serviced in 4 years!!!well apparently the head removal is quite easy.. but its not something i would be armed with taking on.
i dunno im a novice
seemed fine. apparently it wont do any harm using lead additive anyway is this true.
Posted 05 September 2007 - 12:16 PM
Posted 05 September 2007 - 12:30 PM
cant see it doing any damage as if its not used it will just burn through to the exhaust.
might just do that then until we get round to doing more with the engine, going for re-spray later on so concentrating on that for now...
Posted 05 September 2007 - 02:09 PM
Posted 05 September 2007 - 02:24 PM
Posted 25 September 2007 - 06:53 PM
This may be obvious to some but how would i know if they are hardened or not ( ie. how are they different?)
thanks
Posted 25 September 2007 - 06:57 PM
Posted 26 September 2007 - 11:28 AM
No lasting damage except to valve seats, which will be ground out and covered if you change to unleaded, though as mentioned is a good chance to fit an unleaded head anyway, theyr'e cheap to buy.
Flowed head, or large valve head will give more power, best to buy from a trusted source if your not that confident, but that aside...
Head change is relatively easy, you can check if it's flat too, and decoke while you've got it off, (scrub the soot deposits away), which will help, especially if your car tends to over run on switch off. Good chance to check valve clearances too, and general service never goes amiss...
D
Posted 26 September 2007 - 11:44 AM
