Posted 07 September 2007 - 02:23 PM
[/quote]
there 12x7 could i modify the wheel studs so they do fit??
[/quote]
You'd have a job on your hands as you will need to make new drive flanges on the front, and the rear end would need a completely different hub/brake setup I would imagine. Other than that, clearance around the dampers could be an issue, sensible profile tyres for 12 x 7 could be a big pain to get hold of and they probably weigh an awful lot if they are designed for trucks!
Still though, wouldn't be impossible for 100mm PCD drive flanges to be made, and grafting rear suspension assemblies from another car with a 100mm PCD wouldn't be out of the question...just a hell of a lot of work!
