How Do I Remove The Stock Mirror?
Posted 07 September 2007 - 04:01 PM
Can I remove the stalk from the triangular piece perhaps? Or are there fasteners up behind the head liner? I'd rather cut the mirror stalk off at the base and paint over the stump than try to pull the headliner and tear it or make it sag... What's the trick of removal?
Thanks in advance.
Posted 07 September 2007 - 04:08 PM
Posted 07 September 2007 - 04:14 PM
If it's the same as mine, the triangular piece you're looking at is a detachable cover that once lowered will reveal another triangular piece with three screws in it.
Ahhhhhhhh.... I see. Did you pry it off with a small screwdriver or can you remove it with fingertips? It looks all one piece at a glance.
Posted 07 September 2007 - 04:18 PM
You should be able to see where the cover ends - I suppose a screwdriver should pop it off.
Assuming, of course, that we DO have the same type of mirror!
Posted 07 September 2007 - 05:43 PM
Well, mine is very loose - it almost falls off if you touch it!
Good point - I have a 1992 Sprite. Seems to me that they didn't change many of the interior bits over the years though... I'll look for the cover tonight after work. Thanks!
Posted 07 September 2007 - 06:40 PM
JR
Posted 07 September 2007 - 08:18 PM
