Fly wheel advise on replacement
7 replies to this topic
#1 marksmini
marksmini
  • 49,441 posts
  • Name: Mark
Posted 30 January 2005 - 11:05 PM
ok im changeing my clutch and would like to no whats best t do
i want to do as much as i can with out going OTT whilest the box it out,
so i was tnking of getting a lightend fly wheel
now is it true that if i wanted a lightend and balenced one i would have to remove my crank to get it set up right??
if so sod that.
if thats the case what up grade fly wheel do you advise, and whats the benifets of getting a lighter one,
aprt fromt he engine can turn over easyer..
will it alow it to rev higher? or pick up faster?
do you recomend doing this and getting one?
thank you
#2 Pavel
Pavel
  • 2,451 posts
Posted 30 January 2005 - 11:08 PM
A lightened flywheel won't make you rev higher, it'll make you rev faster. Will increase acceleration a good bit...
Only drawback is that idle becomes somewhat lumpy!
#3 siggy
siggy
  • 1,110 posts
Posted 30 January 2005 - 11:25 PM
Idle only becomes lumpy with Hi lift or scatter cams.
The increase in acceleration is noticable, but not fantastic
You should really have the flywheel balanced with the rest of the engine.
Siggy
#4 Pavel
Pavel
  • 2,451 posts
Posted 30 January 2005 - 11:42 PM
Sorry wrong choice of words. Not necessarily lumpy idle but basically the car will be more prone to stalling...
#5 marksmini's better half
    Marksminis Wifey
  • 1,172 posts
Posted 31 January 2005 - 05:56 PM
prone to stalling... !!
is it worth replaceing it then?
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 31 January 2005 - 06:56 PM
You won't have any issues with a road spec lightened flywheel, and you will notice the extra acceleration and faster starting. You'd only really notice the problems with lightened flywheels if you were shaving off insane competition amounts of metal from it, but that's why they make road spec and race spec wheels. The standard item can easily afford to loose a few pounds with no ill effects.
The benefit is that each pound lost from the flywheel effectively removes about 80 pounds from the load on the engine when it accelerates the car (in first gear, it's all due to the gearing which is why you don't see any more performance at the top end of fourth gear). The actual saving in your case depends on your wheels, gearbox, final drive and stuff but that's a good rule of thumb.
#7 marksmini's better half
    Marksminis Wifey
  • 1,172 posts
Posted 03 February 2005 - 12:13 AM
thanks dan, thats help me decide what to do ,
cheers mate
#8 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 03 February 2005 - 10:29 AM
just had mine and maxmax's lightened. They are verto flywheels so theres not as much to take off as on a pre-verto but it should still b noticable!
Posted Image :grin: :grin:
