Is Nitrous Ok For A 998
Posted 09 September 2007 - 07:36 PM
also how much will it all cost
is it good to make up a kit or buy one thank you
Posted 09 September 2007 - 08:45 PM
Posted 09 September 2007 - 09:16 PM
Posted 09 September 2007 - 11:00 PM
Posted 09 September 2007 - 11:29 PM
Posted 10 September 2007 - 12:08 PM
Theres always a progressive nitrous set up like they used in the mentalist MG SV.
Posted 10 September 2007 - 12:54 PM
best to get it wired into a microswitch on the accelerator or carb too rather than having a switch so that its only activated on full throttle. least it can be set up properly then.
Posted 10 September 2007 - 01:40 PM
To be honest, with a 998 you probably wouldn't need to change that much, especially with just an extra 25bhp going through it, unless you were planning on shooting it all through at the redline! To be honest if you want speed then I don't think NOS is the way to go. It has its uses on the drag strip, but the NOS is soon used up and your back to a slow 998! Plus i doubt your insurance company will touch you with a kit installed.
But NeilG is right, go to specialists like was.
Posted 10 September 2007 - 02:22 PM
another thing is that nitrous is only activated on full throtle, so if your foot is 95% of the way down it will not be delivered.
Posted 10 September 2007 - 02:42 PM
All depends how you have it set up I believe. I think you can either have it progressive or set as a shot whenever you press a button, or just on what, but I could be wrong..another thing is that nitrous is only activated on full throtle, so if your foot is 95% of the way down it will not be delivered.
Posted 10 September 2007 - 03:31 PM
Posted 15 October 2007 - 10:57 PM
if you look under the 4 carbs, you'll see where the 4 NOS powerfogger nozzles are mounted, the braided hoses with the red unions are for fuel, these run under the seat to a 4 way splitter, then connects to the solenoid which contains the jets, then a facet redtop connects to that. the blue unions run the nitrous oxide, which again run to a 4 way splitter, then the solenoid with suitable jets, then the bottle.
