Maestreo 5 Speed
9 replies to this topic
#1 simini22
simini22
  • 23 posts
  • Local Club: SYNT classic car club
Posted 10 September 2007 - 10:24 PM
how easy? i'm sure there was one in a mini van or pickup owned by a plant or farm machine firm in mini world a few years back but all it said was it was an easy fit???
#2 not so mini dan
not so mini dan
  • 374 posts
  • Local Club: NA
Posted 10 September 2007 - 10:34 PM
You could always put the entire Maestro engine in your mini, would solve any potential compatability problems :o
#3 Ethel
  • 26,078 posts
Posted 10 September 2007 - 10:38 PM
You'd have to - you couldn't screw the maestro clutch on to the Mini crank. For all the work involved you may as well choose a better engine.
#4 nev_payne
nev_payne
  • 2,249 posts
Posted 10 September 2007 - 10:40 PM
i was under the impression the maestro box arrangment results in the gear chage rod being stuck out of the front of the car?
#5 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 11 September 2007 - 04:02 AM
not really worth doing a maestro engine swap with the other current options on the market.
orver honda vauxhall suzuki etc etc probably cheapest to do a suzuki or vaux swap. have a look at Purple Tom's vaux engined clubby or Pandoras Suzuki engined one. or ed4rans for a RWD suzuki
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 September 2007 - 06:49 AM
There was, and it was a maestro block, but it was a Mini 5 speed box, not the Maestro gearbox attached. It appeared in a mag, probably about a year ago.. and raised the same question... the owner actually popped on to TMF and confirmed the above.
The maestro/montego 1.3 is an A series, but the gearbox is side mounted... this has been fitted to a mini, but you'll also notice that the engine is rotated by 180 degrees, so the carb is positioned at the front and normal ancillaries at the rear...
Probably easier, to do a 1.4 K series conversion.
#7 simini22
simini22
  • 23 posts
Posted 11 September 2007 - 09:37 AM
i see thought it a bit sus that we wernt all ripping meastros to bits for the gearbag
#8 nev_payne
nev_payne
  • 2,249 posts
Posted 11 September 2007 - 10:06 AM
hmmm hence why there are barely any A-Series metros around anymore :o
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 September 2007 - 10:28 AM
Nothing wrong the the maestro/montego block/head however, and because they are the wrong way round, they resited the oil filter up onto the block twin point stylee... makes for a good mini engine
#10 Big_Adam
Big_Adam
  • 7,435 posts
Posted 11 September 2007 - 11:07 AM
Simple solution.
Put the engine in the back. RWD! WOO!
