Posted 04 February 2005 - 07:07 PM
Guessworks is right, there is a complex reflector 7" H4+sidelight headlamp available which is E-marked. It's not a halo type, but it is complex reflector. It might be a Cibie unit.
This is a grey area in the law though. Technically an MOT tester is within his rights to fail you if your lamps don't have an E-mark. BUT, if you take an SVA they don't need to be. They will pass if they can be 'demonstrated to perform in an equivalent manner to a unit with an approval mark', which means if they have the right beam pattern they should pass whether marked or not. So if they pass the SVA, they should pass an MOT (and that is a lot cheaper than Euro-type testing). The German tests are also equivalent, so a unit marked as having passed the TUV (or maybe it's the other test for an individual item, but I can't remember the name of it) would also be acceptable. Basically, the European Union isn't a federal government so their mark isn't binding.
And you might have a slim chance of getting away with pale yellow sidelights, as yellow is also allowed for headlamps in Britain (like French cars). But I am reasonably sure that you still have to have white sidelights as you can probably only have yellow sidelights if you also have yellow headlamps. And I think that most cars that were sold here with yellow headlamps (which hasn't happened for a long time) had seperate sidelights which were always white.
Red, blue or green would be right out though as Guessworks said.
