Help, I have twin air horns but every time I use them they start with a feeble toot and then just wheeze. I've tried adjusting the plastic tubing so there are no kinks but with no success.
Anyone got any ideas how I can fix them?
If not, any ideas where I can get a decent loud horn - need it for my commute round the North Circular Road every day.
Many thanks
M
My Air Horns Are Out Of Breath!
MaryMoo
, Sep 15 2007 11:09 PM
7 replies to this topic
Posted 15 September 2007 - 11:09 PM
Posted 15 September 2007 - 11:17 PM
Is the compressor running from the original horn wiring?
Posted 15 September 2007 - 11:23 PM
As far as I could see, yes. Would this cause the problem and does it mean a bit of rewiring?
Many thanks
M
Many thanks
M
Posted 15 September 2007 - 11:33 PM
Find the inlet port of the compressor ans squirt some oil in there. put a little in the supply hose as well.
This is a routine maintenance item for air horns
Posted 15 September 2007 - 11:36 PM
Many thanks - will give that a try in the morning.
M
M
Posted 16 September 2007 - 03:51 PM
I've never had to oil air horn compresors to be honest, but I have found the wheezyness to be due to poor electrical connections. The compressor uses a lot more juice than a standard horn and can struggle to get enough power down the existing wire. It is better to run these from a new circuit on heavy cable using a relay connected into the original horn system to trigger it.
Posted 16 September 2007 - 04:15 PM
Aye, get a relay on that thing.
...be MUCH louder then.
Posted 16 September 2007 - 10:35 PM
Tried the oil today and worked a bit better but not as I had hoped. Will try the new circuit and see how that works.
M
M
