Steering Locks And Indicator Stalks
Posted 16 September 2007 - 08:26 PM
i have a "K" reg cooper thats race inspired and i have my fibreglass race dash, only problem being the dash hits the stalks and cannot even get the ignition key in,
so could i remove the indicator stalks to toggle switches on me dash (and they will be labbled)
do this for,
indicators
high beam
windscreen wipers
and also move the ignition key to the dashboard, thus disabling the steering lock,
my question being i have heard rhumors that you need a steering lock for MOT reasons, is this true or can i get away withwhat i want to do
would just make everything so much easier to fitting the dash, and look the cats pajamas
gaz
Posted 16 September 2007 - 10:12 PM
Posted 16 September 2007 - 10:49 PM
Posted 16 September 2007 - 10:57 PM
Indicators don't have to self cancel for the MOT.
You might need indicator, horn and flasher/high beam switches in reach of the wheel.
and there might be an issue if they're considered dangerous (sharp) to bump in to
Gonna be a very busy dash if they're all separate switches
Posted 17 September 2007 - 08:06 AM
Posted 17 September 2007 - 08:07 AM
Ive got a 1978 mini and the indicators don't cancel as standard!!
Posted 17 September 2007 - 07:05 PM
then all i need is high and low beam on the dash
and horn in the cntre
jobs a good-un . . . .????
Posted 19 September 2007 - 09:31 AM
Exactly the same as my old mini, you'll probably find he has a battery cut off switch, which is allowed in place of the steering lock. If you don't have a steering lock you'll need another 'immobilising device' like a battery cut off.My mate has got a road legal race mini and he has no steering lock and he has a puch start instead of the usual ignition. His has passed two MOT's with the mod, so that seems to be legal. He's even been stopped by police for a ramdom vehicle inspection (which they do a lot round here) and they said nothing about it.
Posted 19 September 2007 - 11:05 AM
Posted 19 September 2007 - 11:09 AM
They should do, after market steering wheel by any chance?
Posted 19 September 2007 - 03:02 PM
Yeah, was gonna say, my 1971 FReaK self cancels!
Posted 19 September 2007 - 03:22 PM
Posted 20 September 2007 - 08:56 PM
This happened to anyone else?
Posted 20 September 2007 - 10:13 PM
yeah i had a 1985 mayfair that self canceled untill i put a mountney wheel and boss on!
When you put the mountney boss on, there should two pins that you tap into on the back of the boss. You then position the plastic collar on the steering rack so that the arrow points in the direction of the wiper stalk. When you slide on the boss, make sure the pins slide in the gap in the plastic collar, fit steering wheel and voila, self cancels
Posted 20 September 2007 - 10:18 PM
My indicator stalks spin freely on the column because the plastic clamp broke!
Yes, this happened to me as well
Mine cost me £8 from a show.
