Engine Tweaking
10 replies to this topic
#1 Mini_Maniac
Mini_Maniac
  • 83 posts
Posted 19 September 2007 - 10:23 PM
Hello all! I started work on my mini this week and have managed to get it running, i basically serviced the engine and played around with a few bits and bobs then fired it up and she runs treats!
Theres alot of work that needs doing to it ( like floorpans, brakes, suspension etc )
I would like to start getting some new bits for the engine as its looking pretty sad and battered, starting with a decent carb set-up.. Would i be able to fit twin 1 1/4" carbs to a standard 998cc or do i have to upgade other bits?
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 19 September 2007 - 10:26 PM
*sighs*
David Vizard - How to tune the A Series engine.
It will tell you EVERYTHING about tuning.
Also, twin 1.1/4inch carbs will fit fine.
#3 Mini_Maniac
Mini_Maniac
  • 83 posts
Posted 19 September 2007 - 10:28 PM
Lol sorry you've probably been through all this before.
Ill look out for that, cheers fella
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 19 September 2007 - 10:45 PM
Adam to the rescue :) :cry:
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 19 September 2007 - 10:54 PM
Ah don't worry about it. I'm just a miserable git. The Vizard book will give you LOTS of info for tweaking your 998. From carbs to cam choice to block work.
*puts on cape, stand in front of fan*
#6 Sprocket
Sprocket
  • 7,266 posts
Posted 19 September 2007 - 11:03 PM
Captain TBASE :cry:
Now your going to ask what TBASE means
#7 stickycreambun
stickycreambun
  • 1,865 posts
Posted 20 September 2007 - 06:51 AM
Captain TBASE :cry:
well?!
#8 Sprocket
Sprocket
  • 7,266 posts
Posted 20 September 2007 - 10:38 AM
LOL
Ok
The book Adam keeps talking about used to be called before revision three ' Tuning BL's A Series Engine' T. B. A. S. E.
#9 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 20 September 2007 - 10:42 AM
Actually, I might do a topic about which literature is worth reading and pin it at the top of technical and problems.
Oooh, another good read (though old) is 'How To Modify Your Mini' but Captain HTMYM doesn't have the same ring to it as T-BASE! :cry:
#10 Big_Adam
Big_Adam
  • 7,435 posts
Posted 20 September 2007 - 11:13 AM
Think someone did a topic on basic tuning a while ago. Then it vanished into the depths of the forum.
#11 Mini_Maniac
Mini_Maniac
  • 83 posts
Posted 20 September 2007 - 05:36 PM
Ordered a copy of that book 2day from Amazon, along with a few other handy manuals i may need!! Cheers guys
