Orange Stuff In Radiator?
11 replies to this topic
#1 Joef
Joef
  • 518 posts
Posted 20 September 2007 - 06:49 PM
This is quite a wierd question and I'm sure It's something simple!
A while a go the mrs had a leaking radiator pipe in her 205 and after replacing it I noticed that there was a 'lump' of rusty orangey coloured gooey something in the coolant overflow tank. Then a couple of days ago i checked mine to see if the water level was ok and the water in mine looks the same colour!
Is it something that people put in there? Some sort of coolant?
:cry: :)
Thanks in advance.
#2 *DJH*
*DJH*
  • 4,972 posts
Posted 20 September 2007 - 06:50 PM
The engine and radiator needs a flushing agent. :cry:
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 20 September 2007 - 06:54 PM
To put it simply, the blocks rusting.
Mini's do it as the block is basically a lump of iron so it rusts. Using the right mix of anti-freeze help but it's nothing to be worried about the rusting I mean, you'll want to flush the coolant system out.
Take the bottom rad house off and dump the hose down it. Then when the water runs clear out the rad put the bottom pipe back on and fill the rad from the hose. Run to temp then drop the water. Keep doing that till it runs clear....or clearer. Then top the lot up with deionized and anti-freeze.
#4 Joef
Joef
  • 518 posts
Posted 20 September 2007 - 06:55 PM
Edit: That's not so good then! Ok thanks for that, I'll flush it out on sat. So what was the gooey stuff in the 205?
Thanks :cry:
Edited by Joef, 20 September 2007 - 07:00 PM.
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 20 September 2007 - 06:57 PM
Ok thats good then! So what does it do?
Clears the C**p out. Might even drop the engine temps a bit if they've been getting a little high.
#6 Jammy
Jammy
  • 25,397 posts
Posted 20 September 2007 - 06:58 PM
Also, used distilled water when you fill the radiator back up!
#7 Big_Adam
Big_Adam
  • 7,435 posts
Posted 20 September 2007 - 06:59 PM
Thats the one,
#8 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 20 September 2007 - 07:13 PM
Red orange is rust, fix it and fix it right :cry:
#9 Joef
Joef
  • 518 posts
Posted 21 September 2007 - 04:44 PM
Yea I will do. ;D
Any idea why it wasnt just liquid though? What would the gooey stuff have been?
#10 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 21 September 2007 - 05:25 PM
A mix of nasty gooey rust and crud,.....
Also at some point it may well have had some 'Bar leaks' or a simliar agent introduced to the system,... basically a liquid you pour in that coagulates aruond any small splits in your radiator etc and stops the leak.
It is, however,... a bodge.
#11 Sprocket
Sprocket
  • 7,266 posts
Posted 21 September 2007 - 05:43 PM
LOL, just been watching Mythbusters. They were trying to kill a V8 small block with any means that is commonly suggested, so while they were at it the checked out the Egg in the rad to stop leak theory. LMFAO, it worked astonishingly well, and real fast too. I was well surprised as were they.
#12 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 21 September 2007 - 05:50 PM
;D i heard abuot the egg trick a while ago... Mmmmm, poached anyone?
