Rusty Screws!
18 replies to this topic
#1 minili
minili
    Awesome and Flattering
  • 5,140 posts
Posted 23 September 2007 - 02:19 PM
Yesterday I had a very productive Mini day (see project page) so felt I should continue the trend today.....
Was going to remove my black (grey :teehee: ) number plate light housing and paint it to match the car....
Undid the 3 screws inside the boot (which were alarmingly loose lol) so the housing is no longer attached to the car but for the wiring. So all I had to do was undo the screws on the glass light covers and remove the light units thus leaving me with the bit I wanted to paint :gimme:
Easy........
THINK AGAIN! :D
The screws look to be rusted on :ermm: they are sufficiently tight that trying to undo them just meant I was stripping the cross off the screw head so I sprayed some WD40 on them and waited a bit (ok only 10 minutes) and I still can't move them at all.
Will waiting on the WD40 actually work (and if so how long?) or is there anything else that the wonderous TMF users can suggest to help me get the screws undone quickly? I don't do waiting!
#2 rozzer!
rozzer!
  • 2,367 posts
Posted 23 September 2007 - 02:23 PM
Easy........
THINK AGAIN! :D
see minty page!
#3 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 23 September 2007 - 04:32 PM
can you grab the heads of the screws with a pair of mole grips and undo them that way?
#4 adcyork
adcyork
  • 490 posts
Posted 23 September 2007 - 04:37 PM
or cut a slot in the head with a hacksaw and use a flat screwdriver if the crosshead is totally kaput.
#5 Steve W
Steve W
  • 313 posts
  • Local Club: mkrufc
Posted 23 September 2007 - 04:40 PM
or. drill the head off, and get hold of the thread with previously mentioned mole grips!
#6 binge
binge
  • 2,508 posts
Tape the lenses up! :D
#7 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 23 September 2007 - 05:02 PM
Grip the unit in a vice and knock the edge of the screw head anticlockwise with a small pointed (so it digs in) drift and hammer
#8 minili
minili
  • 5,140 posts
Thing is, I was going to do that until I realised that I had to remove them to get the housing away from the car - I don't want to spray it while it's still attached because I don't want to get any overspray on the car (obviously I'd mask the area but would rather have it all out the way)
#9 1984mini25
1984mini25
  • 8,785 posts
Posted 23 September 2007 - 05:04 PM
Or disconnect the wiring connectors near the fuel tank and remove the boot lamp and wiring clear of the car so you can work on it easier.
#10 backstreetclassics
backstreetclassics
    Previously known as minidan07
  • 1,898 posts
  • Local Club: essex mini club
Posted 23 September 2007 - 05:05 PM
some one you know must have a spare if not ill bring 1 to the ace cafe for you 2 paint along with some chrome trim for your window rubbers :D
#11 Steve W
Steve W
  • 313 posts
Posted 23 September 2007 - 05:06 PM
cut the wires off on the inside of the boot. then reconnect them when you're done with some spade connectors!
#12 minili
minili
  • 5,140 posts
Posted 23 September 2007 - 05:20 PM
some one you know must have a spare if not ill bring 1 to the ace cafe for you 2 paint along with some chrome trim for your window rubbers :gimme:
But if I can't get the old one off.... :teehee: It doesn't matter how many people have spares if the old one's still stuck on :D lol
But thanks for the offer! What I'm going to do is try and repaint it and then maybe for the long run get a chrome one and chrome handle set
#13 Ethel
  • 26,077 posts
Posted 23 September 2007 - 05:27 PM
You'll still need a couple of lenses 'n bulb holders I'd think
#14 mk1leg
mk1leg
  • 9,343 posts
Posted 23 September 2007 - 05:40 PM
(Undid the 3 screws inside the boot (which were alarmingly loose lol) so the housing is no longer attached to the car but for the wiring. So all I had to do was undo the screws on the glass light covers and remove the light units thus leaving me with the bit I wanted to paint)
pick up a secondhand unit or soak old unit in desil for a few days this should do the trick :D ..mk1leg
#15 backstreetclassics
backstreetclassics
  • 1,898 posts
Posted 23 September 2007 - 05:43 PM
if i give you a spare with lenses you can just pull the wires of yr old one and theat way you dont have to worrie about undoing the rusty screws let me know
