The Spraymate is a high volume low-pressure compact spray set-up, which is more economical than conventional spray methods. The system gives a contained operation, which is directional with little or no over spray. It is a complete plug in and go system, consisting of a 1000w 2 stage turbine, 5metres of flexible hose and a spray gun. The Spraymate is ideal for workshop and home use and is suitable for spraying a variety of finishes, cellulose, emulsion, gloss, lacquers, timber preservatives and varnishes.
Seems like it might be a good alternative to buying expensive spray equipment if you only plan to do a minimal amount of spraying?
