Ideal Water Temp
Posted 07 October 2007 - 08:27 AM
Anyways, driving on the motorway for the first time the water temp stayed at about 70 - 73 ish then when I hit town driving it went straight up to around 80 - 90. Is this ok?
Also I think it may have just carried on climbing a bit if I had to sit in traffic for a bit but luckily it was fairly moving. Another thing is that the car is fairly hesitant before the cam cuts in - which is about 3 thousand revs. Is this normal? and is it ok to drive around at say 1500 - 2500 revs when there is no cam or will damage the engine or cause it to overheat etc?
What is an exceptable engine temp and at what temp should I start to worry?
Many thanks in advance.
Posted 07 October 2007 - 09:16 AM
As for the cam kicking in at 3000rpm, I've little experience of cams but i believe the 286 is fairly racey so that sounds about right.
Someone else might give you a fuller explaination, but it doesn't sound like there is anything wrong. Also do a search for Kent 286, you will find quite a few threads on cams.
Posted 07 October 2007 - 05:53 PM
Posted 07 October 2007 - 06:01 PM
Posted 07 October 2007 - 06:19 PM
My pickup has an MG Metro 1380 with a two-core rad and 74deg thermostat. I've been told that the Metro engine tends to overheat and so a 2-core rad is a good idea. In summer it's great because I never have to worry about overheating no matter how much stop-start driving I do, but in winter it runs too cool so I'll have to address that one soon.
You shouldn't have any problems, the thermostat will control the engine temperature regardless of how effective the cooling system is.
Posted 07 October 2007 - 10:55 PM
Cheers for thatYou shouldn't have any problems, the thermostat will control the engine temperature regardless of how effective the cooling system is+
Posted 08 October 2007 - 06:41 AM
In my last Mini i had a 1410cc engine that caused me a few cooling problems. I tried a 4 core radiator, which didn't work, so i fitted a Minispares super cool 2 core, and it was fine after that.
The thermostat controls the temperature to a certain extent, but most cars have a bypass hose, so coolant can still flow round the engine. If you don't have a bypass hose, (Metro engines didn't) then you should have some holes drilled into the thermostat to allow water to flow when the thermostat is closed. This can mean that the car doesn't get up to temperature in the winter.
There is a lot of debate about what is the correct number of holes to drill in a thermostat, i found that 3 x 3mm holes is perfect for our MG Metro engine in the estate....
Posted 09 October 2007 - 08:20 PM
Also the idle was slightly down than normal. Today was idling at about 800-950 whereas before it was on about 1000-1100. Again just put this down to the change in weather.
Posted 09 October 2007 - 10:19 PM
Posted 11 October 2007 - 07:04 PM
Edited by oggy1380, 11 October 2007 - 07:05 PM.
