Exhaust Glowing Cherry Red After 2-3 Mins Of Runin!
11 replies to this topic
#1 parma
parma
  • 47 posts
Posted 13 October 2007 - 04:26 AM
hey
i started up mi mini after getttin the head done and putting the engine bk in, i ran it onli for a couple of minutes but the single, centre exhaust off the manifold glowed red so fast, but the other 2 didnt.
is there ne reason its doing this? or is this the norm?
cheers for ne replys
mat
#2 Jammy
Jammy
  • 25,397 posts
Posted 13 October 2007 - 06:09 AM
Check your battery and earth straps. It sounds very much like the battery strap has been touching the exhaust, has melted the outer sheath and the engine is now earthing itself through the exhaust system.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 October 2007 - 06:21 AM
or it's just running extreemely lean !
#4 Jammy
Jammy
  • 25,397 posts
Posted 13 October 2007 - 06:27 AM
Oooor, you've inadvertedly fitted an F1 engine to your car.
#5 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 13 October 2007 - 08:46 AM
That would be clumsy!
#6 jayare
jayare
  • 2,093 posts
Posted 13 October 2007 - 12:37 PM
But would make an awesome 'Non-Mini Engined Projects' thread!
JR
#7 Ethel
  • 25,987 posts
Posted 13 October 2007 - 01:03 PM
Could be an exhaust valve thing check your tappets 'n get the compression tester out if you can lay your hands on one.
#8 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 16 October 2007 - 01:56 AM
Good Lord , what has he got as a battery ? If the earth was glowing red hot , then wouldn't the positive feed as well ?
I would tend to look at extremely retarded timing , plug leads swapped or exhaust valves hanging open.
#9 Jammy
Jammy
  • 25,397 posts
Posted 16 October 2007 - 08:19 AM
I suppose it depends on the material the current is flowing through?
#10 pinch
pinch
    Das Pingu's
  • 527 posts
Posted 16 October 2007 - 10:33 AM
retarded timing......
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 16 October 2007 - 11:58 AM
Check the static timing but it sounds like a way lean fuel/air mix to me.
#12 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 16 October 2007 - 12:08 PM
Yes either very lean or very retarded timing.
Is it better if you pull out the choke giving you a richer mixture?
