Bhp-hp Conversion?
Posted 16 October 2007 - 09:55 PM
Posted 16 October 2007 - 10:01 PM
That sort of spec usually makes about 65bhp, basically same as a 1275 but less torque
Posted 17 October 2007 - 01:05 AM
the "brake" is a british thing
its like fries = chips and chips = crisps
Edited by minimarco, 17 October 2007 - 01:08 AM.
Posted 17 October 2007 - 02:31 AM
Posted 17 October 2007 - 02:33 AM
SPEC: 33.3mm In. 29.2mm Ex. Combustion Chamber Volume 24cc
12G295 casting. The ultimate small bore head. Modified to suit all fast road/rally engine specifications. Suits race small bores.
http://www.minimania...D/InvDetail.cfm
Is this the right head previously mentioned? What would be the best carb set up to go with the 12g295 head?
Edited by Neb, 17 October 2007 - 02:40 AM.
Posted 17 October 2007 - 05:51 AM
GT4L
the one on minimania is a modified head from a 12g295 casting. i think minimadmike was talking about a stock 12g295 cooper head. which should cost less than half of the longman head....if you could find one....and unmolested...so you could molest (skim) it and get the CR right to work with you 998..and unleaded conversion + likely needs new valves and stuff. so it shouldnt be a bolt on thing. or instead of finding a cooper head, you could mod your standard head to stage 3 spec.
are you running on 12's or 13's
Edited by minimarco, 17 October 2007 - 05:53 AM.
Posted 17 October 2007 - 06:39 AM
1 hp = 1Bhp
No it isn't, the Brake is the manner in which the power is measured, using an brake dynamometer, for instance I use waterbrake here at work, but we're also getting a motoring dyno, which is electrically braked and will produce power to run the site, clever huh!
However it is about a direct conversion, there's also P.S. in Germany, and all sorts of others...
D
Posted 17 October 2007 - 07:14 AM
1 hp = 1Bhp
D
to my understanding, which is very limited, they are the same thing. the americans just dropped the word brake.
speaking of clever, a few gyms here are harnessing the power from the treadmills and stationary bikes to power traffic lamps and such.
Posted 17 October 2007 - 08:03 AM
....A 12G295 cooper heasd will fit straight on....
No it won't! You have to measure the chamber size and if its not been molested before you'll need to skim the head to get the correct compression ration. This is very important, if you put the head on as standard then the engine will run very poorly!
Posted 17 October 2007 - 11:27 AM
1 hp = 1Bhp
D
They didn't so much drop it, as just didn't use it, they tried to go all SAE, however as stated they do correlate directly, as long as measured in the same place, e.g. flywheel, two rollers, chassis dynamometer, etc.
That is also quite clever! We've been trying to get our dyno's to run the site for ages, with up to six 12 litre diesel engines running tests we can have thousands of kW output, enough to sell quite a lot back to the national grid!
D
Posted 17 October 2007 - 08:29 PM
I'm running 12's. Tossing around a few ideas but want to get the mechanics and rust spots sorted asap. She runs fine a bit rich but I'm going to take care of that soon. I'm just looking for a bit more push for daily traffic and hills. The more the better, as long as she doesn't break every day, but budget is an issue.the one on minimania is a modified head from a 12g295 casting. i think minimadmike was talking about a stock 12g295 cooper head. which should cost less than half of the longman head....if you could find one....and unmolested...so you could molest (skim) it and get the CR right to work with you 998..and unleaded conversion + likely needs new valves and stuff. so it shouldnt be a bolt on thing. or instead of finding a cooper head, you could mod your standard head to stage 3 spec.
Posted 17 October 2007 - 08:45 PM
Yeah my bad. I basically meant it'll fit without the need for any block work.
Posted 17 October 2007 - 09:22 PM
