Cracked Manifold!
9 replies to this topic
#1 insamoufonyx
insamoufonyx
  • 1,633 posts
  • Local Club: NorthSomersetMiniClub.co.uk
Posted 17 October 2007 - 05:01 PM
ok, so just been doing all my cheaks for my mot, will it fail on a cracked manifold? for are the not likely to notice?
and what can i do about it?
cheers
#2 black jack1275
black jack1275
  • 276 posts
Posted 17 October 2007 - 05:12 PM
I think it may fail, all depends on the tester.
my old mans rover had a blowing manifold and it failed, all i did was put some exhaust putty over the crack then replaced the heatshield.
he`s still driving around like it 5 months later.
#3 miniracer15
miniracer15
  • 45 posts
  • Local Club: Oval Race Club Sussex
Posted 17 October 2007 - 05:18 PM
All depends on were the crack is and if its very obvious !
#4 stretched
stretched
  • 295 posts
  • Local Club: www.mmc.uk.com
Posted 17 October 2007 - 05:39 PM
If any part of an exhasut system is blowing it should fail an m.o.t
But as you say, its up to the tester
#5 Jammy
Jammy
  • 25,397 posts
Posted 17 October 2007 - 06:07 PM
Not quite sure thats true stretched, but then it might be one of these interprutation things. I had a blowing exhaust join on my MR2, but because it didn't affect the emissions it was ok for the MOT.
#6 black jack1275
black jack1275
  • 276 posts
Posted 17 October 2007 - 06:25 PM
Just been on UKMOT.com website and found this:
a. check the exhaust system for leaks
b. Note: A durable repair to an exhaust system which effectively prevents leaks is acceptable providing the system is structurally sound
c. Note: A minor exhaust leak from, for example, a connection joint or a pin hole, is not a reason for rejection.
So you might get away with a blowing manifold
#7 insamoufonyx
insamoufonyx
  • 1,633 posts
Posted 17 October 2007 - 07:06 PM
it looks like a fairly major crack, its up top where the make badge is, should i put some exhaust putty over it and hope for the best?
#8 Jammy
Jammy
  • 25,397 posts
Posted 17 October 2007 - 07:23 PM
You could always take it down to your MOT guy and ask him/her?
#9 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 17 October 2007 - 08:35 PM
Clean it off with a wire brush and stick some JB weld on it, works a treat.
#10 Bass Man
Bass Man
  • 321 posts
  • Local Club: London & Surrey MOC
Posted 19 October 2007 - 02:00 PM
My daughters Mini failed on a wheel bearing, the blowing exhaust was just a recomended....
