Cutting Out
Posted 25 October 2007 - 08:17 AM
managed to get it restarted and limp home has anyone had the same problem or any ideas. its just had a new dizzy, rotor arm, ht leads, plugs, coil, points and condensor
only thing i need to check is to see if the plugs are oiled or coked up if its not that im stumped
Posted 25 October 2007 - 09:12 AM
What made you change all your ignition components in the first place?
Posted 25 October 2007 - 10:31 AM
Posted 26 October 2007 - 04:22 PM
Posted 26 October 2007 - 06:58 PM
Posted 27 October 2007 - 09:32 AM
baffling me now because i dont know if it is a fuel problem or the coil breaking down even though its only a month old
Posted 27 October 2007 - 10:55 AM
Posted 28 October 2007 - 06:36 PM
took the dizzy cap off and the points were very slightly corroded even though its only a month old!! i gave these a quick tickle and re-fit the car did run better but still have the same niggle but nowhere near as bad......
is it worth changing the dizzy cap and seeing if this could be the problem
Posted 15 November 2007 - 06:45 PM
Posted 18 November 2007 - 03:22 PM
but it only seems to happen when i use my lights or windscreen wipers it will drive fine for a while and then out of no where it feels like i have a rev limiter and it shudders and wont accelerate ive had my mate check it out and he cant find the problem im stumped and the b***h is i need my car for work cause there's no buses that early any help would be hugely appreciated
ax
Posted 30 November 2007 - 01:23 PM
Posted 30 November 2007 - 01:31 PM
Edited by t@z, 30 November 2007 - 01:41 PM.
