Mk1 Door Hinges On Mk3
Chewy
, Oct 26 2007 10:35 PM
9 replies to this topic
Posted 26 October 2007 - 10:35 PM
Hey All
If i change the a panels to mk1 panels can i have mk1 hinges if i put stiferners in the doors
Posted 27 October 2007 - 06:31 AM
speak to dogmatrix, i believe he was doing this on his old project
Posted 27 October 2007 - 06:51 AM
one of the mini magazines did this conversion on theirs
cant remember what mag or what month
Posted 27 October 2007 - 11:51 PM
its impossible unless you replace/mod the A panels and inner a panels
Posted 28 October 2007 - 12:17 AM
Doors are heavy you'd need to add a fair bit of bracing. Apart from the holes the A panels are a different shape as the doors vary at the bottom.
Posted 28 October 2007 - 03:01 PM
As far as I know, to do it properly, you need:
Mk1 inner and outer A panels (theres 2, double skinned)
Mk1 hinges
Mk1 doors
To do it on the 'cheap' you need:
Mk1 inner A panel and later normal outer A panel
MK1 hinges
Later doors need to be drilled and strengtheners put inside.
Mk1 hinges
Mk1 doors
MK1 hinges
Posted 28 October 2007 - 03:52 PM
doesnt anyone do fibreglass mk1 hinges? fake ones basically.
that way you can have the look, without the added hassle?
Posted 28 October 2007 - 04:59 PM
look at how your doors open and you will see its not possible
when the door opens it moves fowards
Posted 28 October 2007 - 05:32 PM
yeah, but i'm sure it can be done so that one slides over the other, they'd be hollow/thin so there must be a way of doing it??
i'm gonna go and give it a try!!!
Posted 28 October 2007 - 05:55 PM
hi there, we tried to do this, got a bodywork & fibreglass specialist on it but to no avail, the end result was pretty hideous and the sliding hinge invention did not work well either as they jammed constantly because mini doors never open the same way twice....lol
fake hinges require to much of a gap to make them look convincing.
One friend we have has had them airbrushed on (as in in paint) and they look amazing. you could try that as the results are quite realistic.
KC
KC
